-   -   3.0 MFI build by www.tech9.ms (http://forums.pelicanparts.com/911-engine-rebuilding-forum/846112-3-0-mfi-build-www-tech9-ms.html)
pht9 01-09-2015 11:19 PM
We recently completed this 3.0 engine to be used for Tarmac Rally events in the UK and Europe.
I also run a similar single plug version in my grey 911 SCR that is successful as a circuit racer and tarmac/tour event rally car here in the UK
I thought the details may be of interest to some of the readers here
Engine is based on a 911SC, aluminium block (930/10) - retains 3.0 Capacity
Layout of components, prior to build
https://farm8.staticflickr.com/7515/...1c4efb0a_c.jpg
Tech 9 Custom pistons and conrods
https://farm9.staticflickr.com/8562/...3c133755_c.jpg
Mahle Cylinders, machined for accuracy (bore perpendicular to mounting faces) then plated with ceramic composite
https://farm8.staticflickr.com/7505/...5c93c1b1_c.jpg
Cylinder heads twin plugged and new sodium filled Intake and Exhaust valves installed
https://farm8.staticflickr.com/7485/...e3a31231_c.jpg
Ports machined for flow and accuracy of mounting to intake manifolds, Injector ports added for MFI injectors
Heart of the beast ! – here you can see the large capacity GT3 Oil pump, one piece steel Intermediate gear, Crank and con-rod assembly, cases with shuffle-pins installed on the main webs. To ensure this lot don’t burst out, secured with ARP Porsche specific engine fasteners throughout
https://farm8.staticflickr.com/7574/...84c709d9_c.jpg
Build completed
https://farm8.staticflickr.com/7504/...78f403f0_c.jpg
Details, Details……. Magnesium High Butterfly 50mm Intake system, MFI Red Top RSR Fuel Pump
https://farm8.staticflickr.com/7536/...ba79a149_c.jpg
Pre-Dyno – Installed on our engine test bed to bed in camshafts and set ignition timing, set throttle butterflies etc
https://farm8.staticflickr.com/7570/...5286fe13_c.jpg
Dyno testing – Final results 308bhp @ 7600rpm with 233 ft/lbs torque @ 5300rpm with silencing requirements met to allow for MSA event testing
Built as a rally specification engine with good low-mid range torque characteristics, the torque curve is very flat. In race/circuit specification the power output would be closer to 340bhp
https://farm8.staticflickr.com/7542/...acf468b7_c.jpg
pht9 01-09-2015 11:22 PM
Tech 9 Custom exhaust system with equal length stepped headers, with merge collectors
https://farm9.staticflickr.com/8653/...3086d14e_c.jpg
https://farm8.staticflickr.com/7510/...50707457_c.jpg
https://farm9.staticflickr.com/8640/...fae87114_c.jpg
nikke911 01-10-2015 12:36 AM
Beautiful!!
3literpwr 01-10-2015 04:42 AM
I'm at the tail end of a similar build, but mine will be on carbs. What is the finish on your fan?
Great work!
silverc4s 01-10-2015 08:54 AM
Looks wonderful! I like the 308hp from 3.0L, what comp ratio? any other details welcomed. Thanks for sharing.
pht9 01-10-2015 11:22 PM
Great work!
Thanks !
The fan and housing is finished by careful Vapour blasting the original magnesium parts, then we apply the Chromate process, that gives the wonderful period look.
This can only be used on Mag casings, not Aluminium.
evan9eleven 01-11-2015 02:46 AM
Wow, that is a thing of beauty!
Let me ask an uninformed question: why choose MFI over other options? Seems most guys are doing carbs and EFI with these ITB setups, but I'd love to understand more about going mechanical.
pht9 01-11-2015 03:03 AM
Using MFI is about using period parts (original design and construction parts/technology from the era that the car is built i.e. Historic classes)
The efficiency could be improved using modern technology, but for historic competition use where the events are regulated and compliance with FIA Homologation, then modern intake systems are not allowed.
There is also the rarity factor to contemplate, when this engine is installed into any vehicle, its both a talking point and adds desirability/value to the vehicle in question.
It's not a cheap exercise installing this system, and for a vehicle that is not being used in FIA events you could save $$$$'s by using a modern system, but as always with anything in life, I guess its down to personal choice and budget consideration.
pht9 01-11-2015 03:14 AM
For anyone that wants to hear what this engine sounds like, a short video to entertain !
In-Car Tour Britannia - SCR 3.0 | Tech9 News! | Tech 9
billybek 01-11-2015 04:26 AM
That was a fun ride! Thanks for posting it.
Sounds great!
evan9eleven 01-11-2015 04:28 AM
Thanks for the info. The sound definitely lives up to the beautiful engine. :)
nikke911 01-11-2015 07:50 AM
I would be interrested in a similar exhaustsystem only for a slightly bigger engine.
Reg. Nic
JV911SYDNEY 01-11-2015 01:25 PM
nice, very nice
Lapkritis 01-21-2015 11:46 AM
I'm interested in the shrouding - where do you source that from? Nice build - very clean.
pht9 01-22-2015 01:11 PM
We have them produced for us by a composites specialist in Europe.
It's not easy getting the 'honey' coloured material to look correct, it also gets better with age, as the set on my engine approaches 3 years old
pht9 03-15-2017 11:23 AM
we have built a number of these engines since this thread was posted
all parts available from stock to build new complete engines, or we can supply short motors for final completion to desired specification
evan9eleven 03-15-2017 11:35 PM
Hey pht, maybe you could post a link to your shop/website so we all learn a bit more about your location and services? Builders with engine dynos are rare up here in the north so its good to know who has the resources.
I assume you also do full builds with EFI and the associated tuning?
pht9 03-18-2017 12:50 AM
we are Independent Porsche Specialist | Porsche Parts and Sales from Tech9
yes, we can assist with standard, concours or bespoke engine rebuilds from 356 to 997
Cairo94507 03-18-2017 05:46 AM
Work of art!
Paul 911 04-11-2017 02:35 AM
Very Nice!
What size tubing is the exhaust header made from ?
NickP 05-02-2017 09:16 PM
This engine is a work of art. I swear I've run through this thread 10 times....
jm993rs 05-06-2017 02:16 PM
Very very very good Job !!!!
Is one littlel dream !!! http://forums.pelicanparts.com/support/smileys/wat1.gif
JmuRiz 05-08-2017 06:09 AM
Makes me wish I could afford to buy the MFI system a friend has, as his client just went high butterfly :(
This 3.0 MFI is such a great looking engine, with power numbers to back it up!!!
panzerfaust 05-16-2017 07:03 AM
stunning beauty of a motor... thank you for sharing
H-viken 05-16-2017 08:00 AM
What parts would have to change to go from 308 to 340? Cams only?
