3.0 MFI build by www.tech9.ms
We recently completed this 3.0 engine to be used for Tarmac Rally events in the UK and Europe.
I also run a similar single plug version in my grey 911 SCR that is successful as a circuit racer and tarmac/tour event rally car here in the UK
I thought the details may be of interest to some of the readers here
Engine is based on a 911SC, aluminium block (930/10) - retains 3.0 Capacity
Layout of components, prior to build
Tech 9 Custom pistons and conrods
Mahle Cylinders, machined for accuracy (bore perpendicular to mounting faces) then plated with ceramic composite
Cylinder heads twin plugged and new sodium filled Intake and Exhaust valves installed
Ports machined for flow and accuracy of mounting to intake manifolds, Injector ports added for MFI injectors
Heart of the beast ! – here you can see the large capacity GT3 Oil pump, one piece steel Intermediate gear, Crank and con-rod assembly, cases with shuffle-pins installed on the main webs. To ensure this lot don’t burst out, secured with ARP Porsche specific engine fasteners throughout
Build completed
Details, Details……. Magnesium High Butterfly 50mm Intake system, MFI Red Top RSR Fuel Pump
Pre-Dyno – Installed on our engine test bed to bed in camshafts and set ignition timing, set throttle butterflies etc
Dyno testing – Final results 308bhp @ 7600rpm with 233 ft/lbs torque @ 5300rpm with silencing requirements met to allow for MSA event testing
Built as a rally specification engine with good low-mid range torque characteristics, the torque curve is very flat. In race/circuit specification the power output would be closer to 340bhp
Old 01-10-2015, 12:19 AM
Tech 9 Custom exhaust system with equal length stepped headers, with merge collectors
Old 01-10-2015, 12:22 AM
Beautiful!!
Old 01-10-2015, 01:36 AM
I'm at the tail end of a similar build, but mine will be on carbs. What is the finish on your fan?
Great work!
Old 01-10-2015, 05:42 AM
Crusty Conservative
silverc4s's Avatar
Looks wonderful! I like the 308hp from 3.0L, what comp ratio? any other details welcomed. Thanks for sharing.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 01-10-2015, 09:54 AM
Great work!
Thanks !
The fan and housing is finished by careful Vapour blasting the original magnesium parts, then we apply the Chromate process, that gives the wonderful period look.
This can only be used on Mag casings, not Aluminium.
Old 01-11-2015, 12:22 AM
evan9eleven's Avatar
Wow, that is a thing of beauty!
Let me ask an uninformed question: why choose MFI over other options? Seems most guys are doing carbs and EFI with these ITB setups, but I'd love to understand more about going mechanical.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 01-11-2015, 03:46 AM
Using MFI is about using period parts (original design and construction parts/technology from the era that the car is built i.e. Historic classes)
The efficiency could be improved using modern technology, but for historic competition use where the events are regulated and compliance with FIA Homologation, then modern intake systems are not allowed.
There is also the rarity factor to contemplate, when this engine is installed into any vehicle, its both a talking point and adds desirability/value to the vehicle in question.
It's not a cheap exercise installing this system, and for a vehicle that is not being used in FIA events you could save $$$$'s by using a modern system, but as always with anything in life, I guess its down to personal choice and budget consideration.
Old 01-11-2015, 04:03 AM
For anyone that wants to hear what this engine sounds like, a short video to entertain !
In-Car Tour Britannia - SCR 3.0 | Tech9 News! | Tech 9
Old 01-11-2015, 04:14 AM
UnRegistered User
billybek's Avatar
That was a fun ride! Thanks for posting it.
Sounds great!
Bill K.
Old 01-11-2015, 05:26 AM
Thanks for the info. The sound definitely lives up to the beautiful engine.
2004 Boxster S
Old 01-11-2015, 05:28 AM
I would be interrested in a similar exhaustsystem only for a slightly bigger engine.
Reg. Nic
Old 01-11-2015, 08:50 AM
Skunk works
JV911SYDNEY's Avatar
nice, very nice
964 RS-4
Old 01-11-2015, 02:25 PM
Straight shooter
Lapkritis's Avatar
I'm interested in the shrouding - where do you source that from? Nice build - very clean.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 01-21-2015, 12:46 PM
We have them produced for us by a composites specialist in Europe.
It's not easy getting the 'honey' coloured material to look correct, it also gets better with age, as the set on my engine approaches 3 years old
Old 01-22-2015, 02:11 PM
we have built a number of these engines since this thread was posted
all parts available from stock to build new complete engines, or we can supply short motors for final completion to desired specification
Old 03-15-2017, 12:23 PM
Hey pht, maybe you could post a link to your shop/website so we all learn a bit more about your location and services? Builders with engine dynos are rare up here in the north so its good to know who has the resources.
I assume you also do full builds with EFI and the associated tuning?
2004 Boxster S
Old 03-16-2017, 12:35 AM
we are Independent Porsche Specialist | Porsche Parts and Sales from Tech9
yes, we can assist with standard, concours or bespoke engine rebuilds from 356 to 997
Old 03-18-2017, 01:50 AM
Cairo94507's Avatar
Work of art!
'71 914-6 #0372
'17 Macan GTS
Old 03-18-2017, 06:46 AM
Very Nice!
What size tubing is the exhaust header made from ?
Old 04-11-2017, 03:35 AM
