| Registered Join Date: Nov 2001 Location: Santa Cruz, Ca
				Head nuts coming loose
			This is the 3rd time that I have had head nuts come loose.  2nd on a 3L and 1st on a 3.2. The 3.2 was built by a renowned engine builder, so I need to think that it happens. When I told him I was getting oil seepage he knew right off the head nuts were coming loose. The other 2 were steel studs in 930 case. No dilivar studs. The studs are not coming out of the case. The nuts are just coming loose. All studs were wire brushed clean and oiled along with the nuts and washers. All studs were torqued to 26 ft lbs. How common is this? Why is it happening? Just re-torque them and go down the road? How often should they be checked?
				__________________ ___________________ Steve- 62 356 S90 Sunroof-sold 11/16  73 911 No longer Targa-3.2L Running GT4 88 Carrera G50 sold 2019 2015 Cayman GTS | ||
|  08-21-2015, 11:27 PM |
| Registered Join Date: Oct 2008 Location: Nash County, NC.
			Spec on a 3.2 is, off the top of memory, 15 ft# then 90 degrees swing which surpasses the 25 ft # for the 3.0 Bruce | ||
|  08-22-2015, 03:59 AM |
| Registered Join Date: Feb 2004 Location: UK
			15Nm or 11 ftlbs followed by 90 degrees for the 3.2 33Nm or 24 ftlbs for a 3.0 litre The extra preload is possibly to prevent the head lifting due the extra force produced by the larger capacity and shouldn't really make much difference to the nuts coming loose. I would think that the tightening strategy used for the 3.2 produces a preload increase of between 10 and 15% but should give a significant reduction in the scatter of the preload. It is a tightening method I would prefer but I am not sure this is the cause of the problem. I am not aware that the Workshop Manual recommends re-torqueing as this seems risky without checking that cams will still turn and that the cam carriers a still correctly aligned. | ||
|  08-22-2015, 06:11 AM |
| Under the radar Join Date: May 2007 Location: Fortuna, CA. On the Lost Coast near the Emerald Triangle
			What lube was used on the threads?  Were the nuts re-torqued after 500 miles?
				__________________ Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage | ||
|  08-22-2015, 08:03 AM |
			Motor oil.  No, not retorqued.  Nowhere can I find that re-torquing is required.  In fact, h ave read that it is not required. Beginning to wonder about that premise.
				__________________ ___________________ Steve- 62 356 S90 Sunroof-sold 11/16  73 911 No longer Targa-3.2L Running GT4 88 Carrera G50 sold 2019 2015 Cayman GTS Last edited by SRT356/911; 08-22-2015 at 08:21 AM.. | ||
|  08-22-2015, 08:18 AM |
			Gordon, I am interested to understand more about re-torqueing as this is something we never undertake and we have never had any problem. When you re-torque do you take off the chain covers and check cam rotation or do you assume that there will be no change from the original build? I would worry that re-torqueing could disturb the cam carriers but may be I am just over-cautious. | ||
|  08-22-2015, 08:21 AM |
			When I rebuilt my '71's motor many years ago, I was told by the experts at the time to re-torque my head nuts after about 500 miles.  IIRC I backed off each nut just enough to make sure it was loose, less than a quarter of a turn, then tightened them to the correct torque.  That was in 1985 and the motor is still running strong. Wayne, in his book, recommends re-tightening the head nuts at 500 miles. I would like the experts to chime in on this as I am in the process of building a 3,0 motor and am interested in the details of this procedure.
|  08-22-2015, 08:44 AM |
			As would I, Gordon.  Asked an expert about adjusting the valves and retorqueing the heads and was told it was not necessary.  Clearly, that didn't work out too well.  I can see the valves not needing adjustment.
|  08-22-2015, 08:49 AM |
				 | Quote:
 It also states that if the cam does bind to undo the nuts and change the tightening sequence until the cam is free to rotate. The comment is made that 'there will be a tightening sequence that allows this to happen'. There is no mention of re-torqueing. If to re-torque you loosen the nuts then my concern is that any checking of the cam rotation will be rendered invalid and some distortion of the carrier could occur and with all the chains and rockers in place it would be hard to know if this had happened. This raises some questions, an I am sad to say I don't have the answers The first question concerns the cam carriers - are later 4 bearing carriers stiff enough that any deformation become irrelevant and it is only the early 3 bearing units that are an issue as they may not have the same level of integrity. The second is whether backing off the nuts is a good thing. With some of the early Coventry Climax race Engines we build we do retorque but we don't loosen the nuts first. It would be very helpful to gather more information. Last edited by chris_seven; 08-23-2015 at 12:15 AM.. | ||
|  08-23-2015, 12:02 AM |
| abit off center |
			it would be interesting to use some Dykem and see whats really turning?
				__________________ ______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. | ||
|  08-23-2015, 06:05 AM |
| Registered Join Date: Mar 2004 Location: Windsor, CT
			4-bearing cam tower are not stiff enough. It is definately possible to have the cam bind during the torquing process.  My LHS did. Had to loosen the nuts and change the sequence. 100% possible. I thought the guidance was to check the torque. Not loosen and retorque. The difference being you only try to tighten the nut and expect no motion, but could tolerate a small angular motion. I also had an exhaust (Dilivar stud was not broken) nut loosen. Likely lubricated by rocker shaft leakage. Reinstalled and retorqued. Unfortunately the damage was done. Head gasket was already damaged and did not survive another track day. I thought the recommended lubrication was anti-seize. Not engine oil. Anti-seize should have a lower friction coefficient, hence a higher preload , and less chance of loosening. | ||
|  08-23-2015, 06:25 AM |
				 | Quote:
 There re some vey expensive nickel based compounds with values of 0.11 but they are normally for high temperature use and tend to be very expensive. Engine oils seem to have K factors of about 0.12 to 0.15 at room temperature and this suggests that there is not much difference in either lubricant. Engine oils will not allow as many re-tightening cycles but for this application that may not be a consideration. The manner in which the stud/nut is lubricated and how it is tightened may have a significant impact on behaviour. A typical nut factor for a dry steel nut could be 0.5 or higher for stainless steels. These figures reduce significantly with lubrication but most quoted values assume that the faying surface of the nut/washer are also lubricated. If only the thread is lubricated nut factors can increase significantly and then the preload could suffer quite badly. I am not sure if the figures quoted by Porsche are for dry or lubricated nuts. We tend to oil the studs and nuts but dry them prior to tightening. The material used for the stud and the nut will also have an impact with Stainless Steels and Inconel being more sensitive to the manner in which they are lubricated and the way in which they are tightened and typically have higher K Factors. I am confident that the way in which head nuts are lubricated and tightened will be relatively inconsistent with most individuals having their own preferred method. It seems to me that if we were to use a stud/nut with either a specific coating or use a specific lubrication method we could eliminate some of the variability which may be the root cause of the problem. There is also a question as whether it is too little preload allowing the nut to shake loose or if it is too much preload causing some stress relaxation in the thread of the case and hence loss of preload. I can believe that if we measured the real preload in a range of studs we could see a 30% variation within a single engine and probably 50% if we measured a few engines. Trying to determine what is happening could be tricky and I think needs some further investigation.   Last edited by chris_seven; 08-23-2015 at 07:49 AM.. | ||
|  08-23-2015, 07:28 AM |
			Chris Variation in cf is probably the strongest reason to go to angle of turn. Takes friction out and relies on the accurately cut threads to control stretch. Would the 3.2 procedure be ok for the 3.0? I'd think it would be, since all the parts in the assembly are the same/similar. | ||
|  08-23-2015, 11:31 AM |
| Registered Join Date: Jul 2006 Location: S. Florida
			When I installed ARP head studs in my 930 motor with red loctite on the case end threads I used ARP Ultra Torque Assembly Lubricant 100-9908 on the 12 point nut threads and the surface of the ARP forged steel washers where the nuts contact them.  That's what the ARP install directions said to do. I'll check the torque on the nuts next time I do a valve adjustment. I didn't like the little squeezed out mess of this stuff in there after tightening the head stud nuts so I sprayed a bunch of brake clean in there to rinse it off afterwards. A paint spray gun filled with mineral spirits at 120psi adjusted for a conical spray pattern does a better job of rinsing it off and it's more economical than multiple cans of Brake Clean. This is the thread lubricant I used and one small packet of it is a little more than enough for the 24 head studs and nuts on a 911 motor. http://www.summitracing.com/parts/arp-100-9908?seid=srese1&gclid=CLSo8OzJwMcCFYoTHwodYfcD_w | ||
|  08-23-2015, 06:06 PM |
			It has been recommended by Porsche, I have read, that anti-seize should be used on the head nuts. The concern I have with respect to retorquing is the starting friction. I'm not sure that is the correct term. I am referring to the force required to start the nut turning. Once the nut is turning it requires less torque to turn the nut than it did to start the nut turning. That is why it has been suggested to back off the nut slightly then re-torque. Maybe this is unnecessary, and perhaps, I am over thinking it.
|  08-23-2015, 08:22 PM |
			Interesting comments. I would agree that a low initial torque followed by an angle will reduce the variation in preload quite significantly and can't see why there should be any difference between a 3.0 and a 3.2. The preload will increase slightly but I would believe that this is well within the capacity of the engine case. The use of ARP Ultra Torque will substantially affect the preload for a given torque and if you torque to the figure in the spec book then you will have a higher than standard preload, I am not sure how much of an issue this is but I would worry about magnesium cases. The stiction between the nut and the washer will be quite significant and would equate to a significant percentage of the 11ftlbs used by the torque/angle method for a 'dry fastener' If you have carefully lubricated the head nut with anti-seize then the stiction will be much lower and although it will still have some influence. The more you think about tightening cylinder head nuts on a 911 the more you realise that is really is a 'black art'. For engines without gaskets I am not sure if re-torqueing is needed and I am not sure if a CE ring qualifies. | ||
|  08-24-2015, 03:52 AM |
| Registered Join Date: Jul 2012 Location: Mississippi
			Disclaimer: I'm certainly no engine builder nor claim to be, however: About 1,000 miles after the top end rebuild of my 3.0 SC I assisted in having my valves adjusted and heads re-torqued by an indy whom I consider one of the best in the business that has built a LOT of 911 engines over the years. I had replaced the lower row of dilivar studs with steel, and for the procedure he started at the rear of the engine (chain end) and progressed forward re-torqueing the head nuts. All were loose between about 1/4 to 1/2 turn. What I don't remember was whether he did the top row or the bottom row first. A bit shocked as I had followed Waynes procedure of starting in the center and working outwards when the engine was built, I didn't question his procedure as I am more than confident in his abilities and experience. Last edited by SCadaddle; 08-24-2015 at 07:23 AM.. | ||
|  08-24-2015, 07:16 AM |
| Registered |
			What, in theory, would a re-torque accomplish? A torque check I understand.
|  08-24-2015, 08:31 AM |
| Registered User |
			So which side head studs are frequently coming loose... intake or exhaust?
				__________________ Ryan Russell (405) 264-6288 | ||
|  08-24-2015, 08:47 AM |
| Registered Join Date: Oct 2013 Location: Prescott, AZ
			Steve Weiner has mentioned that he has seen ARP studs not hold their preload. Perhaps the material and shank size has a role whether the studs hold their initial torque setting.
				__________________ 1990 964 Coupe 1986 Carrera 3.2 Targa | ||
|  08-24-2015, 08:50 AM |
