-   -   Engine Performance? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/850436-engine-performance.html)
crashmy911 02-06-2015 12:10 PM
Engine Performance?
http://forums.pelicanparts.com/uploa...1423253177.jpg
Engine is 3.0 with 10 3 to1 compression race cams twin plug individual throttle bodies. Trying to determine why it's not making more power. Any suggestions appreciated.
crashmy911 02-06-2015 12:15 PM
http://forums.pelicanparts.com/uploa...1423253724.jpg
crashmy911 02-06-2015 12:16 PM
That is cam profile also running crank fire ignition system and 48 mm ITBs
crashmy911 02-06-2015 01:00 PM
Thought it would pull to 7100 but stops at 6100. Why would this happen?
RD911T 02-06-2015 01:27 PM
I'm no expert, but it has to be your A/F ratio, doesn't it? Are you measuring that when it's on the dyno?
crashmy911 02-06-2015 01:31 PM
It's being minipulated by tuner on dyno .
crashmy911 02-06-2015 01:39 PM
How can you tell if cam isn't set right or if exhaust is causing bottle neck?
Steve@Rennsport 02-06-2015 01:46 PM
There are MANY reasons why its short on power and some of them are:
1) Exhaust system design
2) Cam timing
3) Ignition timing
4) Fuel mapping (AFR's)
5) Injectors mis-sized (duty cycles beyond 80%)
6) Internal drag (many causes)
7) Rings not seated (leakdown tests show this)
8) Heads cannot flow sufficient air to support engine
9) Insufficient octane (I see evidence of possible detonation)
This should help get you started on the process.
crashmy911 02-06-2015 01:52 PM
You see evidence of possible detonation? Maybe u should try another tuner? Any suggestions on east coast?
Sorry maybe I should try a different tuner.
crashmy911 02-06-2015 02:23 PM
Injectors are 30lbs. I think.
crashmy911 02-07-2015 03:59 PM
Anyone want to comment? Could use any info.
jpnovak 02-07-2015 05:14 PM
Hard to comment with one line phrases and not details on the build. I believe Herr Steve gave a nice list of items you need to describe.
al lkosmal 02-07-2015 07:16 PM
+1..........more info required. Try to summarize all of the pertinent info in one message and I'll be glad to review & comment.
regards,
al
crashmy911 02-08-2015 05:39 AM
I'll start another thread with all the information needed to figure out problems. Will get other info from tuner Monday. Thanks
Edelweiss 02-08-2015 01:26 PM
No power...
Dear Sirs,
Steve is 100 % correct in all points.
Working on dynos every day I can't see any evidence for detonation in your sheet.
The TDC lift of your cam is good for a static compression of min 11,5 : 1 I would say if the squish is done right 12,5 : 1 is perfect.
With this cam detonation will just come up with very bad fuel, a very restrictive exhaust and a dramatic wrong ignition adjustment.
But !
The more your TDC lift the more your system gets reactive - so inlet plenum and exhaust must cooperate....then and hust then you will see power !
Best reg.
Dirk
Steve@Rennsport 02-08-2015 03:13 PM
Hi Dirk,
Looking at some of the dyno traces between 5500 RPM and 6K, I see potential evidence of either detonation or intake reversion which can both cause those dips, especially using that camshaft profile.
Without a LOT more details, its virtually impossible to offer anything further, but its certainly cause for review.
Walt Fricke 02-08-2015 04:14 PM
Here is why my first dyno run looked way too low: the butterflies weren't opening all the way.
So that is always worth a check, especially when you aren't even in the ballpark.
Edelweiss 02-08-2015 04:30 PM
The ping
Hi Steve,
i was interpreting it in that way that it is more a pulsing / resonance / mixture effect - also typical on those cams when exhaust is not done right.
For sure you are right - without any more Info it's impossible to say really.
Best reg.
Dirk
Steve@Rennsport 02-08-2015 05:07 PM
Originally Posted by Edelweiss (Post 8477710)
Hi Steve,
Hi Dirk,
I too, have experienced the very same things with that cam when the headers/muffler are wrong. :) :)
Not many people understand how sensitive these engines are about exhaust systems.
Edelweiss 02-08-2015 05:38 PM
The old gas
Originally Posted by Steve@Rennsport (Post 8477770)
Hi Dirk,
So true Steve, and we hear the same - " an exhaust can't make power "
But yes it can, ant when the TDC lift goes up the difference from a very bad to a very good exhaust concept is so huge.
Primary to secondary length / diameter - collector design and reflector to absorber.
It can make an engine alife or kill his good spirit.
Best reg.
Dirk
Walt Fricke 02-10-2015 10:15 AM
Crash
How about changing the graph so RPM instead of speed is shown? I think that is more useful, and the software allows making that change from the data stored from the run.
Looks like a 3d gear run?
The ends of these runs look like either a rev limiter kicked in, or you took your foot off the throttle, not that the engine just wouldn't rev any higher. What was the deal there?
What fuel did you use? If detonation is a suspect, running some 116 octane fuel ought to help see if this is happening, or if it is some mismatch in intake/exhaust resonances.
hdrockerroller 02-16-2015 07:20 PM
Originally Posted by Walt Fricke (Post 8480333)
Crash
Yea I was thinking rev limiter too. Do have an MSD ignition, they have programable rev limit.
Eagledriver 02-18-2015 07:27 PM
If you're only reving to 6100, that explains your lack of power.
-Andy
crashmy911 02-26-2015 08:51 AM
http://forums.pelicanparts.com/uploa...1424969435.jpg
If these Pistons are higher then 10 5 to 1 compression I would need race gas? What do u guys think these would come out as?
crashmy911 02-26-2015 08:53 AM
The engine only went through two pulls on dyno and then was shut down.
crashmy911 03-04-2015 08:32 AM
Just looked at cam timming. Cams are off some. Left side at 5.92 and right side at 5.91. Going to try setting them closer to 5.6.
Walt Fricke 03-04-2015 11:30 AM
1) If you can't post a dyno sheet which has RPM across the bottom, how about you specify the gear you were in (if 6100 was where it shut off, I'm guessing 4th, but no one should have to guess), the ring and pinion, and the ratio for that gear (or, if a stock transmission, which one), along with your rear tire specs.
2) I'm dubious that a changing the cam timing by that amount is going to make much of a difference, but it might. Just be sure you are checking for full throttle butterfly opening.
3) At one time I thought that if you got rid of a rev limiter apparently set at 6,100, you'd get that HP you think you should. But looking at the graphs again, I guess not - since the HP falls off with the torque fall off, rather than continuing to rise as it typically does with race motors and race cams at those rpms (the increased revolutions more than offset the fall in torque), something more serious is going on to kill the breathing.
4) By all means post the new dyno results. I wish I could time my cams within 0.01mm of each other side to side! Anyone who can do that surely can set them to 5.6 without too much trouble.
crashmy911 03-04-2015 02:03 PM
Walt my readings where fast so I'm sure they aren't perfect
crashmy911 03-04-2015 02:09 PM
http://forums.pelicanparts.com/uploa...1425506940.jpg
crashmy911 03-04-2015 02:39 PM
Stock gear box.
crashmy911 03-05-2015 06:22 AM
It's a electramotive tech 3r system
fred cook 03-05-2015 08:17 PM
Engine performance..........
Which heads are you using on this 3.0 engine? If the ports are small, that could be the restriction, especially with the 48mm ITBs.
fred cook 03-06-2015 01:48 PM
Feeling restricted...............
About 2 years ago I built a 3.3SS engine for my SC. It is using 10.1:1 Mahle pistons, KN Engineering 100mm cylinders, 964 cams, Carerra twin plug heads, Electromotive XDi direct fire ignition, CIS induction, etc, etc, etc. As you can see, it is quite similar to the engine in your car except for the intake system. However, my engine will pull like crazy up to the ignition cutout at 7500 rpms. So, it does seem that your engine is restricted somewhere. There is an old saying among hot rodders that the horsepower is in the heads. Since you have the big (48mm) ITBs, hot cams, and direct fire ignition, you might consider the following: 1) Ports in the heads are too small or not matched to the intake diameter, or 2) you are not providing enough amperage to the power for the direct fire coils. If it's the first, it's a case of trying to pull air over a ledge that is causing non laminar flow to the intake ports. The intake size and cylinder head port size should be the same for good flow. If it's the second, then your ignition system just can't supply the spark intensity needed to make power at high rpms. The coils should be operating off of relays that pull current directly from the battery. As a general rule of thumb, expect to need 1 amp of current for each 1000 rpms. So, your system would need to provide 7-8 amps to each coil pack for max power. Happy hunting and good luck!
crashmy911 03-06-2015 02:04 PM
Thanks Mr Cook. I've got early sc heads. The ports where enlarged to mate with manifolds
crashmy911 03-17-2015 01:37 PM
Car at new tuner in Maryland. Behe Performance we will see what he can do with it.
camgrinder 03-18-2015 05:48 PM
I would expect to see a 5500 RPM and up powerband with those cams in a 3.0 litre at 10.3-1 compression. Looks like 5500 RPM is around 75-77 mph on the graph?
Going from 5.91mm to 5.6mm on the cam setting is a little over 1 degree on the centerline. And the wrong direction (retarding them) if you are looking to pick up the hole in the powerband.
Did you try adding fuel? Not saying its a cure, but with these cams the a-f is probably going to end up in the low 12's.
Walt Fricke 03-19-2015 01:41 PM
Crash
The early SC heads are the big intake port heads. They require the larger intake manifolds.
You can open up the ports on the later US heads to match the early/Euro head ports.
But you wouldn't want to try to open up the later, narrower, manifold runners. You could probably do that down at the port flange, but that won't do any good with the air flow out of the air box, where everything needs to be larger as it was on the early SC and the Euros.
If you port matched the smaller port runners to your larger port heads, that might be part of this puzzle.
Perhaps you just misspoke? And you have the larger intake ports and the proper runners to go with them?
crashmy911 03-22-2015 05:58 PM
Heads are 78sc heads. Cams are at 5.7 and 5.8. Best I could do.
crashmy911 03-23-2015 06:03 PM
Tuner has gone to bigger injectors. We will see next week what it will make. Tuner also found problem with TPS sensor.
