totle's Avatar
What is this ?
Doping a top end rebuild of a 2.4E
Found this in the sump plate.
Looks like it is has been cup shaped. Hard plastic.
Looks like it was round, with a bottom. Don't seems like any rubber gasket
Can not remember to have seen similar thing.
I know the engine was rebuilt in the end of the eighties.
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 02-20-2015, 02:41 PM
TibetanT's Avatar
That looks like an oil seal....possibly from the oil pump area. Might have gotten pinched when the build was done?? Just a guess on my part.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 02-20-2015, 02:47 PM
TibetanT's Avatar
Never mind....you said hard plastic and doesn't look like it is part of the chain ramp.
Ed Paquette
1983 911SC
1987 944S
Old 02-20-2015, 02:55 PM
totle's Avatar
Yep, hard plastic.
does not look like the round oil seals from the pump. those has thicker walls as well.
tried to put the parts together, and seems like it is round ans has a bottom
Trond R.
1986 944 Turbo
Old 02-20-2015, 03:30 PM
jjsjws
? looks like plastic (micarta) from spark plug. Have you attempted to "fit" broken pieces together to perhaps help identify original shape?
Old 02-20-2015, 03:42 PM
totle's Avatar
Will try to fit it together with super glue tomorrow.
Trond R.
1986 944 Turbo
Old 02-20-2015, 03:47 PM
Straight shooter
Lapkritis's Avatar
Cap to something that fell in during the last assembly. Perhaps loctite from the 80's.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 02-21-2015, 06:01 PM
totle's Avatar
It is at least something that is not supposed to be there. Not lochtite cap.
Trond R.
1986 944 Turbo
Old 02-22-2015, 05:37 AM
totle's Avatar
Looks like a bushing of sone kind.
But for what?
Trond R.
1986 944 Turbo
Old 02-22-2015, 05:47 AM
Straight shooter
Lapkritis's Avatar
Looks more like a plug. Use on new parts when packaged or on used parts when blasting to keep holes clear.
Old 02-22-2015, 06:05 AM
Maltese Falcon's Avatar
+1
Looks like a "Cap-plug".
Porsche builds the 21st century 9146
so easy...even a Cayman can do it !
Old 02-22-2015, 08:23 AM
totle's Avatar
could be a cap plug of some sort, but this one is very hard. A cap plug would probably be a soft material?
Trond R.
1986 944 Turbo
Old 02-22-2015, 08:56 AM
I don't believe it has a 911 110 xxx xx part number for engine parts.
Bruce
Old 02-22-2015, 09:16 AM
...and there is at least one more piece floating around somewhere.
Old 02-22-2015, 09:24 AM
Looks like a vinyl cap... Maybe someone stuck it into the dizzy hole and she fell in? Can't think of one place that this might belong.
Old 02-22-2015, 10:16 AM
