-   -   Cooling Fan (http://forums.pelicanparts.com/911-engine-rebuilding-forum/853045-cooling-fan.html)
dpetteng 02-23-2015 10:24 AM
Cooling Fan
I noticed my engine had an electric cooling fan above the main fan shroud that looks like it pushes air over the heat exchangers. Do I need this? Does it just make the heating more efficient or does it actually play some part in engine cooling?
Steve@Rennsport 02-23-2015 11:01 AM
That fan blows air through the heat exchangers to provide more consistent levels of heat & defrost in the cabin as well as keeping the headers cooler.
dpetteng 02-23-2015 11:09 AM
OK, understood, so do I need them if I am prepared to accept less consistent cabin heating?
NICE 69 S 02-23-2015 03:57 PM
Where do you live. It's 85 degrees in Los Angeles today and Zero degrees in New York.
I'd leave it in. As Steve states above, it cools the headers.
Bob B
MBAtarga 03-05-2015 08:05 PM
Look up "backdating heat" threads for more information on the blower and associated parts removal.
dpetteng 03-10-2015 12:16 PM
Thanks, I read a bunch or posts about heat backdating so I know what I need to do. One question, where can you get the left and right ducts to backdate your heat. Also, does anyone make a left duct that does not have the "cutout" for the distributor as I wont have a distributor on my build?
Lapkritis 03-16-2015 12:49 PM
You can get the back date parts right from our gracious host.
Right Side Part Number:
911-106-322-01-PH - Pelican Parts - Product Information: 911-106-322-01-PH
Left Side Part Number: 930-106-321-01-PH - Pelican Parts - Product Information: 930-106-321-01-PH
