Cooling Fan
I noticed my engine had an electric cooling fan above the main fan shroud that looks like it pushes air over the heat exchangers. Do I need this? Does it just make the heating more efficient or does it actually play some part in engine cooling?
Old 02-23-2015, 10:24 AM
That fan blows air through the heat exchangers to provide more consistent levels of heat & defrost in the cabin as well as keeping the headers cooler.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-23-2015, 11:01 AM
OK, understood, so do I need them if I am prepared to accept less consistent cabin heating?
Old 02-23-2015, 11:09 AM
Where do you live. It's 85 degrees in Los Angeles today and Zero degrees in New York.
I'd leave it in. As Steve states above, it cools the headers.
Bob B
Old 02-23-2015, 03:57 PM
MBAtarga's Avatar
Look up "backdating heat" threads for more information on the blower and associated parts removal.
Mark
'83 SC Targa - since 5/5/2001
Old 03-05-2015, 08:05 PM
Thanks, I read a bunch or posts about heat backdating so I know what I need to do. One question, where can you get the left and right ducts to backdate your heat. Also, does anyone make a left duct that does not have the "cutout" for the distributor as I wont have a distributor on my build?
Old 03-10-2015, 12:16 PM
Straight shooter
Lapkritis's Avatar
You can get the back date parts right from our gracious host.
Right Side Part Number:
911-106-322-01-PH - Pelican Parts - Product Information: 911-106-322-01-PH
Left Side Part Number: 930-106-321-01-PH - Pelican Parts - Product Information: 930-106-321-01-PH
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 03-16-2015, 12:49 PM
