964 cam install in a 3.0
So I am on the tail end of my engine rebuild and I have a question on my cam install. Obviously the nut and large wavy washer go with the stock cams and I have the bolt and washer that go with the 964 cams.
When I installed the cam it seems like the end shaft of the cam should stick out pretty far past the sprocket but it doesn't stick out very much.
I put the thick washer in bevel facing inward followed by three shims and then the smaller pin sprocket. I tapped the sprocket until it was seated but the shaft does not protrude past the end of the chain sprocket.
Am I doing something wrong or is this what it is supposed to look like?
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 03-01-2015, 05:12 PM
Thinking about it last night I bet the key way popped up in the back and is holding the gear from going all the way back. I will pull it this evening and check it.
Tom Feeney
1970 911 T
1973 911 T
Old 03-02-2015, 04:15 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
I'll bet you 5 bucks you are right. It's quite easy for the key to flip up and out. If you are having difficulty, you could put a tiny dimple on the side of the key so it's fits tightly in the cam. A sharp center punch does the deed but go easy, you don't need much of a hit to get the desired effect.
1986 Targa Guards Red
2021 MT09 SP
Old 03-02-2015, 05:26 AM
Well, you owe me 5 bucks! The key was in perfect and the gear was all the way back.
The gear slides on and off with just a little resistance and it is seated against the washers.
I put the other side on and it is nearly identical.
Any ideas? I have searched for pix of a 964 cam in a 3.0 but no luck.
Someone please chime in.
Tom Feeney
1970 911 T
1973 911 T
Old 03-02-2015, 03:49 PM
Sprocket position
Found this picture that looks a lot like what mine look like
Old 03-02-2015, 06:02 PM
Tom Feeney
1970 911 T
1973 911 T
Old 03-02-2015, 06:10 PM
Cash or PayPal on the 5er? Tom, I don't suppose you have your old cams to compare the depth on the stub on the two cams. I don't know if the the 964 and 3.2 cams are different in that regard but you could contact the cams guys for some advice or check out their catalogs to see if they are different. Going from memory, the last picture you posted looks about right, certainly in your first picture, there is too much distance between the cam end and sprocket.
2021 MT09 SP
Old 03-03-2015, 02:18 AM
That's really pretty close, there is no over proud there.
Did you do chain alignment?
Bruce
Old 03-03-2015, 03:32 AM
Not yet, that might make it better if a shim gets taken out.
I will do the chain alignment and see if it makes a difference.
Tom Feeney
1970 911 T
1973 911 T
Old 03-03-2015, 04:01 AM
If the cam came through the gear you wouldn't be able to measure and shim to parallel and you wouldn't be able to tighten to spec as the chain gear would be loose.
Bruce
Old 03-03-2015, 04:33 AM
michael lang's Avatar
This is how mine came apart. When I packed and labeled everything I used zip ties to keep everything together so I would not have to remember how it came apart.
This is how it looked when I removed the cam bolt
The pin and sprocket
Finally the spacers.
Tom, I hope this helps you figure it out. Just remember going back together is in reverse.
Mike
'89 CARRERA
#402
Old 03-03-2015, 05:30 AM
Good pics and explanation
Not pictured, before the spacers are removed and while doing sprocket alignment the key in the cam needs to be out of the keyway
Bruce
Old 03-03-2015, 08:59 AM
Bruce
I figured that since the washer was conical shaped that it would hold the gear in place.
Tom Feeney
1970 911 T
1973 911 T
Old 03-03-2015, 10:46 AM
I will work on chain alignment this weekend.
Thanks for all of your help. The pictures were a HUGE help.
Tom Feeney
1970 911 T
1973 911 T
Old 03-03-2015, 10:59 AM
The conical side is at the bolt head.
Bruce
Old 03-03-2015, 11:21 AM
Guess I should flip it over when I get home
Tom Feeney
1970 911 T
1973 911 T
Old 03-03-2015, 12:27 PM
So Tom, what happened? Did you get it figured out?
Mike
'89 CARRERA
#402
Old 03-06-2015, 12:54 AM
Couldn't get to it this weekend as I was out of town until Saturday evening. I will get back on it Wednesday.
Tom Feeney
1970 911 T
1973 911 T
Old 03-07-2015, 03:41 PM
Chain alignment
So, checked chain alignment and the right side looked like this
Left side looked like this
I think these are both within specs
Tom Feeney
1970 911 T
1973 911 T
Old 03-08-2015, 04:20 PM
So I am going to put it together
Tom Feeney
1970 911 T
1973 911 T
Old 03-08-2015, 04:21 PM
