gtc gtc is offline
abides.
gtc's Avatar
Servicing Carrera tensioners during rebuild
After a fair amount of searching, I haven't found anything written about servicing pressure fed Carrera tensioners during an engine rebuild. Are there any seals or o-rings to replace, or should I just make sure they're clean and reinstall them?
I do have the two o-rings needed for the covers that are not included in the gasket kit.
Thanks,
Graham
1984 Carrera Targa
Old 03-20-2015, 08:55 AM
abit off center
cgarr's Avatar
I just clean them out, make sure there is not corrosion in the lower part: You can do the stop mod too real easy:
______________________
Craig
G2Performance
Old 03-20-2015, 12:47 PM
