Replacing Tensioners on '73 T
I have a stock '73 T that I recently had Turbo tensioners installed on (I specifically asked for Turbo so that the car would remain "looking stock" and not have the oil feed lines required with the Carrera tensioners).
To confirm that these were actually put on the car, how could I check? |
You will have to pull cover and get a visual
The safety collars should be installed if they weren't. Why are you questioning the work you hired done? Bruce |
Just wanted some way to confirm that the work was done. I had a bit of a sixth sense that it might not have been completed is all.
| All times are GMT -8. The time now is 06:47 PM. |
