Uhrwerken's Avatar
Replacing Tensioners on '73 T
I have a stock '73 T that I recently had Turbo tensioners installed on (I specifically asked for Turbo so that the car would remain "looking stock" and not have the oil feed lines required with the Carrera tensioners).
To confirm that these were actually put on the car, how could I check?
'73 911T Coupe 31K original miles, 2nd owner
'69 Alfa Spider fully restored
'97 Boxster, gone but not forgotten
WTB: '02-'05 low mile 996 GT2
Old 03-07-2015, 07:42 PM
You will have to pull cover and get a visual
The safety collars should be installed if they weren't.
Why are you questioning the work you hired done?
Bruce
Old 03-07-2015, 08:28 PM
Uhrwerken's Avatar
Just wanted some way to confirm that the work was done. I had a bit of a sixth sense that it might not have been completed is all.
Old 03-08-2015, 09:03 AM
Tags
911 2.4 , mechanical , tensioners
