Help! Runaway idle speed
Hello, I'm having some issues with my newly rebuilt engine and am hoping for some forum wisdom. Occasionally, my engine's idle speed will start running away and I have to get off the road and shut down before it gets too out of hand. This only seems to happens when the car is warmer (LA traffic), and always returns to normal once I restart the engine. I'm thinking it may be an Idle Control Valve or Fuel Pressure Regulator problem. Thoughts?
My car is a 90' 964 with 993 vram/injection/DME/Wong chip.
Old 03-07-2015, 11:38 PM
2nd problem
Second problem is that the engine seems to choke up if I move the accelerator too quickly. As in; when 'floored' the engine will make stuttering noises and not give any additional power, but if I roll accelerator on slowly the engine seems to keep up just fine.
-Sam
Old 03-07-2015, 11:41 PM
Air Medal or two
afterburn 549's Avatar
not a whole lot to go on, My guess "false air"
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 03-08-2015, 03:27 AM
txhokie4life's Avatar
Air is entering intake past the what ever air monitoring system you have.
Maybe a leak at the intake runners where as the car heats up gap opens.
I had something similar on my race car.
Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 03-08-2015, 08:09 AM
Did some more experimentation today regarding issue 2 (choking under WOT at higher revs and load conditions); I think it may be a bad resonance flap or something else internal in the varioram. Any ideas?
And thanks for the above replies, I agree that 'extra air' finding it's way in could be an issue, but I still thinking it seems like something's getting stuck then resetting once I restart. So Idle Control Valve or throttle linkage/bell crank.
Thanks again.
-Sam
Old 03-08-2015, 11:22 PM
And Mr. Afterburn 549, we should talk helicopters.
Old 03-08-2015, 11:24 PM
