-   -   Converting case and oil system to JIC Fittings (http://forums.pelicanparts.com/911-engine-rebuilding-forum/858087-converting-case-oil-system-jic-fittings.html)
dpetteng 03-28-2015 01:47 PM
So I have seen a few builds with JIC (AN) fittings for the oil system and considering I am fitting my 3.2 to a VW van I will need to do this as the standard fittings wont work. How hard is it to convert the case, oil cooler and oil tank?
dpetteng 03-30-2015 01:44 PM
Anyone?
gtc 03-30-2015 03:23 PM
Try Pegasus for the adapter fittings.
MikeD 03-31-2015 10:03 AM
You need these. Easy as long as you have clearance for the longer fitting.
https://www.pegasusautoracing.com/group.asp?GroupID=PLUMADAP30MM
