Converting case and oil system to JIC Fittings
So I have seen a few builds with JIC (AN) fittings for the oil system and considering I am fitting my 3.2 to a VW van I will need to do this as the standard fittings wont work. How hard is it to convert the case, oil cooler and oil tank?
Old 03-28-2015, 01:47 PM
Anyone?
Old 03-30-2015, 01:44 PM
gtc gtc is offline
abides.
gtc's Avatar
Try Pegasus for the adapter fittings.
Graham
1984 Carrera Targa
Old 03-30-2015, 03:23 PM
You need these. Easy as long as you have clearance for the longer fitting.
https://www.pegasusautoracing.com/group.asp?GroupID=PLUMADAP30MM
Old 03-31-2015, 10:03 AM
