It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
What magic sauce on intake gaskets???
I can't find any reference to any coating for the intake runner gaskets. Are they installed dry? Thanks in advance.
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 04-09-2015, 03:51 PM
It's a trap...
They're going on naked boys, not torqued though. Any input?
Old 04-09-2015, 04:17 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The use of high quality gaskets in this application is more important than "magic sauce". Good gaskets install dry. Low quality gaskets glue them and pray.
Cheers
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-09-2015, 04:31 PM
It's a trap...
They are Reinz. Is that a good one? Thank you for the reply. I know you are very busy and I much appreciate it. Cheers, Mike.
Old 04-09-2015, 04:36 PM
Victor Rienz is at the low end of the quality chart. There are many that will work but most are substandard. We won't use them on our engine builds not ever in a pinch.
Henry Schmidt
Ph: 760-728-3062
Old 04-09-2015, 04:45 PM
It's a trap...
What should I use? I got these in a kit from here. I thought I was doing the correct thing. Hmmmm.
Old 04-09-2015, 05:20 PM
It's a trap...
Mr. Schmidt are the rest of my gaskets suspect? I'm ordering the OEM intakes now. Should I be concerned about all the other Rienz seals I used for this whole rebuild? Bummer..
Old 04-09-2015, 05:26 PM
At this point your engine is built. If you built your engine with attention to detail you have a reasonable chance of success. I wouldn't worry. My advise for gasket choice is meant to point people in the right direction before the engine assembly starts. We only use gaskets supplied by Wrightwood Racing because we don't see the same quality in the VR gaskets. That said, the intake gaskets just have to seal vacuum. No oil leak possible. Use a little Curil T on the gaskets and you should be OK. Don't over-tighten the nuts.
Henry Schmidt
Ph: 760-728-3062
Old 04-09-2015, 05:36 PM
It's a trap...
Thank you. I feel much better now. Many hours spent cleaning and reading this board so I think I might be alright as you said. Nuts torqued to 18 ft lbs is what I've seen here and in the Bentley on page 102-39 for my SC. Cheers.
Old 04-09-2015, 05:54 PM
