Valve adjustment on a 71 t
I recently adjusted the valves on my 71 911t and now the car will not start. The engine turns but it's not firing. Any idea what the problem might be?
http://forums.pelicanparts.com/uploa...1429501604.jpg |
Did you double check that you got the plug wires seated correctly?
Did you remove the distributor rotor? Check for spark.
The first thing I would check for is spark. While adjusting the 1-2-3 intake valves, you could have knocked something off on the electrical panel to the left?
Bob B |
| All times are GMT -8. The time now is 04:39 AM. |
