Valve adjustment on a 71 t
I recently adjusted the valves on my 71 911t and now the car will not start. The engine turns but it's not firing. Any idea what the problem might be?
Old 04-19-2015, 07:46 PM
DSPTurtle's Avatar
Did you double check that you got the plug wires seated correctly?
Old 04-19-2015, 09:06 PM
Under the radar
Trackrash's Avatar
Did you remove the distributor rotor? Check for spark.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-20-2015, 11:33 AM
The first thing I would check for is spark. While adjusting the 1-2-3 intake valves, you could have knocked something off on the electrical panel to the left?
Bob B
Old 04-20-2015, 03:33 PM
