Henry,
We may not always see eye to eye but I must salute the obvious first class nature of your builds! The motors you and your team put together look to be beyond first class. Best regards, PFM |
I'm sure this is obvious to others, but why does that case and 4/5 bearing mod only done to that bearing and not all of them?
And, as always, stunning work there Henry - the marriage of art and engineering! |
In the past this modification was only performed on race engines but since we do this work in house it seemed reasonable to do it to every engine we build. |
Uhhhhhhh this job is good and all is very beautiful !!
Think you for share........... :eek::eek::eek: |
Also appreciate you doing the legwork to test the springs. Given what other hi po 911 springs & retainers are sold for, it's really easy to question the Eibachs seeming to be too good to be true. |
Somebody's gonna get a mighty fine sports car when all this comes together. If possible, ask him to share one he puts that beautiful motor into the SWT!
This engine is being shipped to KS. so I'll have no control over the install but I'll ask for pictures. |
Funny you should ask.
My father never had a Porsche, but he "heard" they broke down a lot and suggested I stay away. My brother owned a 912 after working as a VW engine rebuilder in the early 70's. He told me to stay away from 911's as they required special tools (true) and would cost a fortune to maintain. To answer your question, it just runs and runs. I drive it at least once a week if not more, it never fails to start and it never has any issues taking me down the freeway at 80 or a back road with plenty of punch. Between Porsche's engineering, the MFI (no carbs to adjust) and your rebuild I am always amazed that a car this old can be every bit as reliable as my boring 21st Century Toyota. Of course, that doesn't keep me from dreaming about owning a coupe with an engine like that SS 2.8!! |
Just remember Dave, we can build you what you want "no matter how much it costs". SmileWavy http://forums.pelicanparts.com/uploa...1432065386.jpg |
Henry,
You should develop and market a "keyboard drool catcher" so that folks can be better prepared for your online builds ... :eek: Thanks for sharing and continuing to do the nameplate proud ! |
Like this?
Order yours now while supplies last. http://forums.pelicanparts.com/uploa...1432485265.jpg |
Although that is a gorgeous engine, I am surprised that given the current state of early 911 prices, that someone would take a number matching engine, and have this done to it. Seems that it would actually devalue the car. Why not take a later engine and do this to it, keeping the original stock? As always, it is the owners choice, but it doesn't really seem there is any value to using the original crankcase in this way.
In any case, if I could afford it, I would put that engine in the middle of my living room as a piece of art. |
Cheers, Harry. |
As for me, while my car is "all stock" on the outside, inside (the engine) Henry made all kinds of mods. New higher compression pistons, case mods for lubrication, more aggressive cams, and additional cooling, all using the stock, numbers-matching magnesium case. And if I wasn't forthcoming about it, no one would be the wiser.
This lets me have more fun with a stock, survivor car without the guilt that comes from destroying it (like so many did in the 80's - 90's). And if I could afford a 2.8SS, and if my 44 year old case could take it, I do it in a heartbeat!!! My $.02 anyways! |
Henry, any updates on this build? More pics please!
Strangely enough, this build is back in front of the line.
Today we start fitting the Amber shroud kit. This sweet kit is coming from 911 Vintage Parts 760-731-4911 info@911vintageparts.com http://forums.pelicanparts.com/uploa...1437490448.jpg |
Very nice, Henry!
Henry, With all the mods you did to the case why did you stick with the old IMS rather than update for the bearing one. Measuring the end play on that oldie looks cool though as does the cover.
Henry, instructive thread on a great engine as others have said.
One question if I may. It looks in the early photos as if you've not installed the crankcase wire mesh screens. I assume this is deliberate (or they went in and the photos were just a mock up), and I'd like to know your reasoning for leaving them out. Is this something you do on all your rebuilds? I have only rebuilt 2 911 engines, both stock, so I am a novice at best, and as a confession I noted the screen absence because I boxed up the last case and then spotted the screens on the bench, so had to reopen, clean, dismantle, fit, rebuild, reseal ...... Oops Mick |
Shim assortments are available from 911 Vintage Parts Ken @760-731-4911 info@911vintageparts.com http://forums.pelicanparts.com/uploa...1437830933.jpg |
Thanks Henry - only ever dealt with early 70's and 60's engines so didn't know that - along with a lot else! So I infer you would actually remove them if you were rebuilding an early engine that originally had them fitted.
Mick |
Henry,
This is exactly the kind of build that gets me going. What fantastic work. The "stock" DeMan rebuilt motor in my 914/6 "needs" a bump up to 2.8 one of these days. What are you running for pistons and cylinders? I take it you are using high performance coatings at least on the pistons, anywhere else? How about cams, spec? Still on carbs as well? What hp are you looking at here? I would love to twin plug mine, but I can't rationalize the cost vs the small increase in performance or am I wrong? It happens. |
Main and rod bearings are dry film Moly as are the piston skirts. Piston domes are ceramic thermal barrier. Rockers are ground, rebushed with DU bushings, threads chased and the pad have dry film Moly as well before being cryogenically treated. Cams are Mod "S". 46 mm Webers rebuilt in house 270 hp ? on street gas. http://forums.pelicanparts.com/uploa...1437844202.jpg http://forums.pelicanparts.com/uploa...1437844218.jpg http://forums.pelicanparts.com/uploa...1437844230.jpg http://forums.pelicanparts.com/uploa...1437844409.jpg http://forums.pelicanparts.com/uploa...1437844427.jpg http://forums.pelicanparts.com/uploa...1437844547.jpg |
Lord help me ... here comes that drool again !
Henry, any objective testing/observations done on the increased wear resistance afforded by the dry film coatings for a street engine ? Bill |
Oh yes, exactly what my dream engine would have. Love the pics.
What we didn't expect was the dyno results. With dry film and our rockers we found 13hp on two separate 2.7 RS engines. Both genuine RS engines produced more than 223 hp with no other modifications. These surprising results were a validation of our efforts to incorporate an old design with modern techniques. |
Nice rockers BTW ;)
Thanks Henry,
Any changes to the recommended oil type used when one goes with the dry film ? Still recommending the Delo 30W ? |
They are available for sale in sets either outright or exchange from 911 Vintage Parts. info@911vintageparts.com or Ken @ 760-731-4911 |
Henry
Fantastic build as usual. Thanks for sharing. Put a kit of the plastic caps and plugs together so we can buy from you. Henry |
wonderful looking build! Im off to start something similar myself! excuse the stupid question, but what is that 4-blade fan on page 2?
This one?
http://forums.pelicanparts.com/uploads24/IMG_5862+11431272760.jpg That is the alternator/fan MOUNT, not the fan. Those four blades are stators that adjust and balance the flow off the fan. |
Henry,
Do you spray a moly coating on the parts? It looks from the rocker photos that I see a freshly bushed/ground rocker and then in the next photo, a dull finish from perhaps a spray coating? I've seen this used on cams to protect lobes during storage/transport/install/initial run-in. Always enjoy seeing your projects and have learned a great deal from your contributions to the Pelican community. Thank you. Cheers, Chet |
We remove the old bushing Black Oxide the rocker Ream the bushing hole Press in the new DU bushing and burnish Surface the contact pad Coat the contact pad with Moly dry film (TLML 2) Treat the rocker to a Cryogenic conversion process Clean adjuster threads with 8x1.0 forming tap. http://forums.pelicanparts.com/uploa...1440778733.jpg |
Henry,
Thank you for all your documentation! What is the 3.0 oil pump flow mod you mention in the beginning of the thread? Peter |
