What the "L", Supertec 2.8
Here's is a new engine build for a 68, soft window 911"L" Targa
Numbers matching case Bored for 92mm cylinders 2.8 Liter twin plug 9.5:1 3.0 oil pump flow mod Case by-pass mod Oil squirters Plugs pulled and threaded Carrillo Rods Case mod for cross drilled crank 70.4 crank cross drilled Stud holes formed for Supertec head studs http://forums.pelicanparts.com/uploa...1430625995.jpg http://forums.pelicanparts.com/uploa...1430626029.jpg http://forums.pelicanparts.com/uploa...1430626331.jpg http://forums.pelicanparts.com/uploa...1430626430.jpg http://forums.pelicanparts.com/uploa...1430626493.jpg http://forums.pelicanparts.com/uploa...1430626551.jpg http://forums.pelicanparts.com/uploa...1430626766.jpg http://forums.pelicanparts.com/uploa...1430626783.jpg http://forums.pelicanparts.com/uploa...1430626794.jpg http://forums.pelicanparts.com/uploa...1430626805.jpg |
Beautiful....
http://forums.pelicanparts.com/uploa...1430750496.jpg
http://forums.pelicanparts.com/uploa...1430750511.jpg http://forums.pelicanparts.com/uploa...1430750532.jpg http://forums.pelicanparts.com/uploa...1430750549.jpg http://forums.pelicanparts.com/uploa...1430750567.jpg http://forums.pelicanparts.com/uploa...1430750591.jpg http://forums.pelicanparts.com/uploa...1430750656.jpg http://forums.pelicanparts.com/uploa...1430750715.jpg http://forums.pelicanparts.com/uploa...1430750730.jpg http://forums.pelicanparts.com/uploa...1430750778.jpg |
http://forums.pelicanparts.com/uploa...1430750969.jpg
http://forums.pelicanparts.com/uploa...1430750996.jpg http://forums.pelicanparts.com/uploa...1430751018.jpg http://forums.pelicanparts.com/uploa...1430751056.jpg http://forums.pelicanparts.com/uploa...1430751082.jpg http://forums.pelicanparts.com/uploa...1430751251.jpg http://forums.pelicanparts.com/uploa...1430751283.jpghttp://forums.pelicanparts.com/uploa...1430751338.jpg http://forums.pelicanparts.com/uploa...1430751358.jpghttp://forums.pelicanparts.com/uploa...1430751440.jpg |
beautiful work Henry
What is the pink looking jig for in the fifth pic of the third post? Is that a piston ring?
http://forums.pelicanparts.com/uploa...1430842401.jpg It is an electric piston ring trimmer. It's used to custom fit rings by adjusting the ring gap to the desired measurement. For years we used the hand crank method but this little tool allows for incredible accuracy and speed as well. |
Yes, that. Cool tool.
True engine porn! Looks amazing.
http://forums.pelicanparts.com/uploa...1430877833.jpg
http://forums.pelicanparts.com/uploa...1430877853.jpg http://forums.pelicanparts.com/uploa...1430877873.jpg http://forums.pelicanparts.com/uploa...1430877889.jpg http://forums.pelicanparts.com/uploa...1430877905.jpg http://forums.pelicanparts.com/uploa...1430877920.jpg http://forums.pelicanparts.com/uploa...1430877940.jpg http://forums.pelicanparts.com/uploa...1430877957.jpg http://forums.pelicanparts.com/uploa...1430877978.jpg http://forums.pelicanparts.com/uploa...1430877996.jpg |
http://forums.pelicanparts.com/uploa...1430878116.jpg
http://forums.pelicanparts.com/uploa...1430878136.jpg http://forums.pelicanparts.com/uploa...1430878155.jpg http://forums.pelicanparts.com/uploa...1430878174.jpg http://forums.pelicanparts.com/uploa...1430878193.jpg http://forums.pelicanparts.com/uploa...1430878216.jpg http://forums.pelicanparts.com/uploa...1430878233.jpg http://forums.pelicanparts.com/uploa...1430878279.jpg http://forums.pelicanparts.com/uploa...1430878305.jpg http://forums.pelicanparts.com/uploa...1430878390.jpg |
Very cool Henry! A VERY lucky guy is getting that engine!
WOW , thanks for sharing Henry. That is just beautiful.
Very cool! Quick question if I might, Henry? I don't think I've ever read about this mod? What's going on here?
http://forums.pelicanparts.com/uploa...1430626029.jpg http://forums.pelicanparts.com/uploa...1430626331.jpg http://forums.pelicanparts.com/uploa...1430626766.jpg |
He is drilling the case for the cross-drilled crank. Notice the larger oil galley hole and the grooved bearing on #5.
Some people groove the crank as illustrated on our SuperCrank but for street use we find grooving the bearing easier. http://forums.pelicanparts.com/uploa...1430925772.jpg |
Nice! I did notice the bearing on #5 was different. I just wasn't sure why the case mod. Please keep it coming. I'll be working on my case soon. Need to get a sealing kit from you , Henry. Will call...
supertec 2/8
Henry, based on your vast experience with building these motors what are you expecting at crank and wheel horsepower (and at rpm) for this build? All other things being equal, what are differences between mfi, webers and newer injections and management in horsepower, torque and mileage figures. thanks for your instructive postings on this list, Henry
The difference between MFI, Webers and more modern systems is a discussion for a thread of it's own. As for mileage: Considering this engine will run 46 Webers, fuel efficiency might be measured in yardage rather than mileage. |
http://forums.pelicanparts.com/uploa...1431045732.jpg
http://forums.pelicanparts.com/uploa...1431045750.jpg http://forums.pelicanparts.com/uploa...1431045767.jpg http://forums.pelicanparts.com/uploa...1431045793.jpg http://forums.pelicanparts.com/uploa...1431045812.jpg http://forums.pelicanparts.com/uploa...1431045834.jpg http://forums.pelicanparts.com/uploa...1431045855.jpg http://forums.pelicanparts.com/uploa...1431045874.jpg http://forums.pelicanparts.com/uploa...1431045896.jpg |
http://forums.pelicanparts.com/uploa...1431046017.jpg
http://forums.pelicanparts.com/uploa...1431046035.jpg http://forums.pelicanparts.com/uploa...1431046058.jpg http://forums.pelicanparts.com/uploa...1431046075.jpg http://forums.pelicanparts.com/uploa...1431046112.jpg http://forums.pelicanparts.com/uploa...1431046261.jpg http://forums.pelicanparts.com/uploa...1431046280.jpg http://forums.pelicanparts.com/uploa...1431046306.jpg http://forums.pelicanparts.com/uploa...1431046323.jpg http://forums.pelicanparts.com/uploa...1431046462.jpg |
Wow! Beautiful! Thanks for sharing.
I see such an incredibly useful technique in this picture. Thank you Henry.
This motor is a work of art.
I noticed that you are using 4 bearing cams. How does this affect the choice of valves and heads? What valve springs are you using? |
Back in the early 60s, factory race engines were built with four, 47 mm journal cams because 4 journal cams offered more stability. In 1975, Porsche decided to make cams for all 3.0 and larger engines with four journals. They also wanted a larger base circle to accommodate higher lift cams so they transitioned to 49mm journals. Being a small company, Porsche elected to make one casting that could function as a three journal 47mm cams or a four journal 49mm depending on the finish machine work. What you see in the pictures are 2.7 liter, 47 mm cam towers that were modified (drilled and plugged) to accommodate a 4 journal 47mm cam. For years, in order to get 47mm 4 journal cams you had to find factory race cams but since the advent of billet cams (from the likes of Andial, DC, Web and Elgin) most cam blanks are 4 journal and the cam grinder just determines what size journal diameter to grind on it. |
2.7 liter cam towers converted for 4 bearing 47mm cams. Note the set screw where the cam tower was drilled and plugged.
http://forums.pelicanparts.com/uploa...1431088426.jpg Because this engine is going in an early version of the 68"L" we also needed to covert the towers to six bolt to accommodate the early aluminum valve covers. The extra studs are removed, the holes drilled and custom made plugs are pressed in then the sealing surfaces are machined flat. http://forums.pelicanparts.com/uploa...1431088453.jpg |
Thanks for the update.
Are the heads 2,4? I think I see a 73 date? Why aren't the combustion chambers chamfered for the larger bore? Who made the pistons? Factory valve springs? I can't wait to see the finished product. Will you be posting dyno runs? |
If you look closely you'll see a slight chamfer. The pistons are made by JE and a closer look at them shows a perimeter flat on the piston dome for piston the head clearance. The valve springs are Eibach racing springs. http://forums.pelicanparts.com/uploa...1431110995.jpg http://forums.pelicanparts.com/uploa...1431111018.jpg Quote:
I just drooled all over my iPad
Simply beautiful work |
Great stuff as always from Henry. What installed height do you choose to set the springs at with the Mod S cams? Reason I ask is because I have a set of the Eibachs for a WebCam 120/104 cam. The 120/104 is a bit more cam than the Mod S (DC 40) and nearly same as DC 60 I believe?
If you set the Eibach spring at around 36mm the seat pressure will be around 90lb and the over the nose pressure will be around 275lb. Those are numbers I could live with. |
One more question. I noticed that the cylinders were not "mooned". Can you give us your thoughts on this mod.
Thanks, |
http://forums.pelicanparts.com/uploa...1431272687.jpg
http://forums.pelicanparts.com/uploa...1431272722.jpg http://forums.pelicanparts.com/uploa...1431272760.jpg http://forums.pelicanparts.com/uploa...1431272786.jpg http://forums.pelicanparts.com/uploa...1431272807.jpg http://forums.pelicanparts.com/uploa...1431272828.jpg http://forums.pelicanparts.com/uploa...1431272865.jpg http://forums.pelicanparts.com/uploa...1431272894.jpg http://forums.pelicanparts.com/uploa...1431272938.jpghttp://forums.pelicanparts.com/uploa...1431273066.jpg |
http://forums.pelicanparts.com/uploa...1431273270.jpg
http://forums.pelicanparts.com/uploa...1431273296.jpg http://forums.pelicanparts.com/uploa...1431273327.jpg http://forums.pelicanparts.com/uploa...1431273390.jpg http://forums.pelicanparts.com/uploa...1431273420.jpg http://forums.pelicanparts.com/uploa...1431273442.jpg http://forums.pelicanparts.com/uploa...1431273505.jpghttp://forums.pelicanparts.com/uploa...1431273932.jpg http://forums.pelicanparts.com/uploa...1431273945.jpg |
Thanks much for the 36mm recommendation. Same as the Eibach published number, but theirs would seem to be just generally speaking and not cam related. I'll be sure to check for coil bind and retainer clearance with the stem seal. Probably not going to be an issue for either of those things but worth looking at since in their measuring things anyway |
As long as your valve lift is less than Eibach's published pressure @ full lift number and you can live with those numbers, you're good to go. If you desire higher full lift (over the nose) pressure then calculating spring height becomes an more challenging endeavor. When we first encountered these springs we were skeptical so we invested time and resources into testing the validity of Eibach's claimed number. At this point we are satisfied that they (Eibach) did their homework. Of course for all of you "engineer types" that struggle with believing an "old dog" you are more than welcome to do your own homework. |
| All times are GMT -8. The time now is 09:30 PM. |
