-   -   What the "L", Supertec 2.8 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/863538-what-l-supertec-2-8-a.html)
Henry Schmidt 05-02-2015 09:22 PM
Here's is a new engine build for a 68, soft window 911"L" Targa
Numbers matching case
Bored for 92mm cylinders
2.8 Liter
twin plug
9.5:1
3.0 oil pump flow mod
Case by-pass mod
Oil squirters
Plugs pulled and threaded
Carrillo Rods
Case mod for cross drilled crank
70.4 crank cross drilled
Stud holes formed for Supertec head studs
http://forums.pelicanparts.com/uploa...1430625995.jpg
http://forums.pelicanparts.com/uploa...1430626029.jpg
http://forums.pelicanparts.com/uploa...1430626331.jpg
http://forums.pelicanparts.com/uploa...1430626430.jpg
http://forums.pelicanparts.com/uploa...1430626493.jpg
http://forums.pelicanparts.com/uploa...1430626551.jpg
http://forums.pelicanparts.com/uploa...1430626766.jpg
http://forums.pelicanparts.com/uploa...1430626783.jpg
http://forums.pelicanparts.com/uploa...1430626794.jpg
http://forums.pelicanparts.com/uploa...1430626805.jpg
Henry Schmidt 05-02-2015 09:31 PM
http://forums.pelicanparts.com/uploa...1430626971.jpg
http://forums.pelicanparts.com/uploa...1430626988.jpg
http://forums.pelicanparts.com/uploa...1430627007.jpg
http://forums.pelicanparts.com/uploa...1430627027.jpg
http://forums.pelicanparts.com/uploa...1430627042.jpg
http://forums.pelicanparts.com/uploa...1430627057.jpg
http://forums.pelicanparts.com/uploa...1430627075.jpg
http://forums.pelicanparts.com/uploa...1430627089.jpg
http://forums.pelicanparts.com/uploa...1430627163.jpg
http://forums.pelicanparts.com/uploa...1430627230.jpg
Jcslocum 05-03-2015 06:26 AM
Beautiful....
Henry Schmidt 05-04-2015 07:48 AM
http://forums.pelicanparts.com/uploa...1430750496.jpg
http://forums.pelicanparts.com/uploa...1430750511.jpg
http://forums.pelicanparts.com/uploa...1430750532.jpg
http://forums.pelicanparts.com/uploa...1430750549.jpg
http://forums.pelicanparts.com/uploa...1430750567.jpg
http://forums.pelicanparts.com/uploa...1430750591.jpg
http://forums.pelicanparts.com/uploa...1430750656.jpg
http://forums.pelicanparts.com/uploa...1430750715.jpg
http://forums.pelicanparts.com/uploa...1430750730.jpg
http://forums.pelicanparts.com/uploa...1430750778.jpg
Henry Schmidt 05-04-2015 07:57 AM
http://forums.pelicanparts.com/uploa...1430750969.jpg
http://forums.pelicanparts.com/uploa...1430750996.jpg
http://forums.pelicanparts.com/uploa...1430751018.jpg
http://forums.pelicanparts.com/uploa...1430751056.jpg
http://forums.pelicanparts.com/uploa...1430751082.jpg
http://forums.pelicanparts.com/uploa...1430751251.jpg
http://forums.pelicanparts.com/uploa...1430751283.jpghttp://forums.pelicanparts.com/uploa...1430751338.jpg
http://forums.pelicanparts.com/uploa...1430751358.jpghttp://forums.pelicanparts.com/uploa...1430751440.jpg
atcjorg 05-04-2015 08:15 AM
beautiful work Henry
Speed Buggy 05-05-2015 06:09 AM
What is the pink looking jig for in the fifth pic of the third post? Is that a piston ring?
Henry Schmidt 05-05-2015 09:14 AM
This thingy?
http://forums.pelicanparts.com/uploa...1430842401.jpg
It is an electric piston ring trimmer. It's used to custom fit rings by adjusting the ring gap to the desired measurement. For years we used the hand crank method but this little tool allows for incredible accuracy and speed as well.
Speed Buggy 05-05-2015 10:20 AM
Yes, that. Cool tool.
Jack Stands 05-05-2015 03:56 PM
True engine porn! Looks amazing.
Henry Schmidt 05-05-2015 07:07 PM
http://forums.pelicanparts.com/uploa...1430877833.jpg
http://forums.pelicanparts.com/uploa...1430877853.jpg
http://forums.pelicanparts.com/uploa...1430877873.jpg
http://forums.pelicanparts.com/uploa...1430877889.jpg
http://forums.pelicanparts.com/uploa...1430877905.jpg
http://forums.pelicanparts.com/uploa...1430877920.jpg
http://forums.pelicanparts.com/uploa...1430877940.jpg
http://forums.pelicanparts.com/uploa...1430877957.jpg
http://forums.pelicanparts.com/uploa...1430877978.jpg
http://forums.pelicanparts.com/uploa...1430877996.jpg
Henry Schmidt 05-05-2015 07:13 PM
http://forums.pelicanparts.com/uploa...1430878116.jpg
http://forums.pelicanparts.com/uploa...1430878136.jpg
http://forums.pelicanparts.com/uploa...1430878155.jpg
http://forums.pelicanparts.com/uploa...1430878174.jpg
http://forums.pelicanparts.com/uploa...1430878193.jpg
http://forums.pelicanparts.com/uploa...1430878216.jpg
http://forums.pelicanparts.com/uploa...1430878233.jpg
http://forums.pelicanparts.com/uploa...1430878279.jpg
http://forums.pelicanparts.com/uploa...1430878305.jpg
http://forums.pelicanparts.com/uploa...1430878390.jpg
nvr2mny 05-05-2015 07:54 PM
Very cool Henry! A VERY lucky guy is getting that engine!
Emo993 05-06-2015 04:55 AM
WOW , thanks for sharing Henry. That is just beautiful.
tharbert 05-06-2015 07:51 AM
Very cool! Quick question if I might, Henry? I don't think I've ever read about this mod? What's going on here?
jpnovak 05-06-2015 08:23 AM
He is drilling the case for the cross-drilled crank. Notice the larger oil galley hole and the grooved bearing on #5.
Henry Schmidt 05-06-2015 08:30 AM
When we cross drill the crank (a mod that adds oil flow to the crank to feed rod bearings #2 & 5) we groove the bearing for constant oil supply. We also increase the volume of oil to the bearing/journal by increasing the diameter of the feed hole.
Some people groove the crank as illustrated on our SuperCrank but for street use we find grooving the bearing easier.
http://forums.pelicanparts.com/uploa...1430925772.jpg
tharbert 05-06-2015 09:30 AM
Nice! I did notice the bearing on #5 was different. I just wasn't sure why the case mod. Please keep it coming. I'll be working on my case soon. Need to get a sealing kit from you , Henry. Will call...
Turbo_pro 05-06-2015 10:22 AM
A small correction just for clarity: the modification in this engine is on the # 4 main bearing.
Henry Schmidt 05-07-2015 08:36 AM
Jim is correct. The bearings are counted from the flywheel forward with the thrust bearing bearing # 1 and the nose bearing being # 8.
