It's a trap...
Houston, we have separtation
My engine separated from the engine stand for the first time in over 1-1/2 years. WooHoo.
Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). |
Try not, Do or Do not
What are you after this time around?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Someday I too will hopefully seperate.
It's a trap...
I had a tensioner fail and the chain did a nice machining job on the oil tray. I took it apart to make sure the aluminum chips were not in the engine. Put everything back stock. Engine sound pad, ss brake lines, shocks and struts, and new inboard CV joints, new clutch and clutch cable "while I was in there". :-)
