Cyl Head exhaust stud spacing dimension?
What is the distance between centers of the exhaust studs in the head on a 1986 911 turbo. I measured 2.575 with calipers. It's hard to measure with the heads on the engine.
Old 09-28-2015, 05:57 AM
crg53's Avatar
It would be a metric measurement.
Measure outside to outside of the studs with your caliber, then measure the stud and deduct that from your first measurement, you should arrive at 66 mm.
Old 09-28-2015, 10:44 AM
