IMR-Merlin's Avatar
getting a slight rap @3k RPM under light throttle
Just got my car running after the engine sat dormant for 5 years and the chassis for 20+.
It's a 3.4 EFI 930 with hydraulic tensioners.
I am getting a rap from 2800-3200 RPM with very light throttle.
I am leaning towards tensioners.
There is no sound on decel nor under moderate and above acceleration.
http://youtu.be/evHQkl6Q1IE
http://youtu.be/pu4xxKKPG7g
I'd like to get this sorted out soon so I can get it to the dyno.
I am running 15/40 Rotella and seeing 2.5 BAR for oil pressure @3k.
This noise is less noticeable when the car is cold. Think 20/50 will fix this issue? I am getting ready to do an oil dump when I get back.
Plan was to run the car for a tank of fuel to get all the residual fuel out and then dump oil and do filter changes.
Fuel, oil and oil screen (pre filter) change.
Old 05-30-2015, 10:36 AM
IMR-Merlin's Avatar
oil pressure issue?
https://www.youtube.com/watch?v=4VWVMNiMS0g&feature=youtu.be
Old 05-30-2015, 01:05 PM
beancounter
jwasbury's Avatar
pressure per gauge does seem a bit low vs. rpm. You might want to verify the gauge and/or sender is operating correctly.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 05-31-2015, 01:26 PM
