-   -   Can these cylinders be saved (http://forums.pelicanparts.com/911-engine-rebuilding-forum/867541-can-these-cylinders-saved.html)
Shaun @ Tru6 05-30-2015 01:55 PM
barn find car had a 2.0 Mg case S-spec engine with Webers. Would have been nice to have been in a barn and not on the side of the house, then half the engine wouldn't have been filled with water time and again.
Also have S heads that are rotten, will post those later.
3 of the cylinders look reasonable though scored. but three like these, can they be saved?
and will it be worth it?
http://forums.pelicanparts.com/uploa...1433019204.jpg
http://forums.pelicanparts.com/uploa...1433019221.jpg
http://forums.pelicanparts.com/uploa...1433019231.jpg
http://forums.pelicanparts.com/uploa...1433019241.jpg
Flat6pac 05-30-2015 03:48 PM
Probably easier to find replacements, might send one out to the likes of EBS and see if they can plate them. All the early stuff with the exception of the T were those cylinders.
Bruce
jhg41977 05-30-2015 06:12 PM
Millennium Technologies may be able to save them. How much is a good set worth?
Shaun @ Tru6 05-30-2015 06:24 PM
Thanks Bruce and Jim. Replacements can be hard to come by these days though it does help that E and S cylinders were the same. They typically come with pistons, a good set is $1K to $2K.
I can send pics to EBS and see what Don thinks. Looked up Millennium, will call them too.
Henry Schmidt 05-30-2015 06:45 PM
Those don'the look saveable.
911 Vintage Parts will have good replacements.
info@911vintageparts.com
Shaun @ Tru6 05-30-2015 07:02 PM
Thank you Henry.
I actually only need one cylinder of the right height group to match the ones for my 69S engine. A mouse lived on top of #3 for many years and pee ate away all the fins. Also fused the head to the studs so that head is similarly ruined.
A friend of mine had these I was considering either using one of the good ones (which may still not be good) or having all of these refreshed and keep mine on a shelf.
Will post more pics tomorrow of P/Cs and heads. Those are scary.
tom1394racing 05-31-2015 04:33 AM
Shaun
I should have some replacements
Shaun @ Tru6 05-31-2015 05:16 PM
Thanks Tom, hopefully I'll be going to NY this week and will stop by.
Here are the heads. I could take a million pics. I think the only way to determine if they are rebuildable is to bring them to Bob at Anchor Atlantic or similar. I cleaned these quickly with soda.
The real shame is that I think every head has something major wrong with it. The one pictured with a nice dome has an eaten away exhaust port and intake valve base is gone. But as 69S heads, I think they should at least sit on a shelf forever if necessary. The ones with bad domes and destroyed seats have good ports. All have an MFI injector hold plugged with a bolt, see top of last pic.
http://forums.pelicanparts.com/uploa...1433117491.jpg
http://forums.pelicanparts.com/uploa...1433117512.jpg
http://forums.pelicanparts.com/uploa...1433117575.jpg
http://forums.pelicanparts.com/uploa...1433117584.jpg
http://forums.pelicanparts.com/uploa...1433117596.jpg
http://forums.pelicanparts.com/uploa...1433117606.jpg
http://forums.pelicanparts.com/uploa...1433117615.jpg
http://forums.pelicanparts.com/uploa...1433117674.jpg
