Shaun @ Tru6's Avatar
Can these cylinders be saved
barn find car had a 2.0 Mg case S-spec engine with Webers. Would have been nice to have been in a barn and not on the side of the house, then half the engine wouldn't have been filled with water time and again.
Also have S heads that are rotten, will post those later.
3 of the cylinders look reasonable though scored. but three like these, can they be saved?
and will it be worth it?
Tru6 Restoration & Design
Old 05-30-2015, 01:55 PM
Probably easier to find replacements, might send one out to the likes of EBS and see if they can plate them. All the early stuff with the exception of the T were those cylinders.
Bruce
Old 05-30-2015, 03:48 PM
Millennium Technologies may be able to save them. How much is a good set worth?
Old 05-30-2015, 06:12 PM
Thanks Bruce and Jim. Replacements can be hard to come by these days though it does help that E and S cylinders were the same. They typically come with pistons, a good set is $1K to $2K.
I can send pics to EBS and see what Don thinks. Looked up Millennium, will call them too.
Old 05-30-2015, 06:24 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Those don'the look saveable.
911 Vintage Parts will have good replacements.
info@911vintageparts.com
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-30-2015, 06:45 PM
Thank you Henry.
I actually only need one cylinder of the right height group to match the ones for my 69S engine. A mouse lived on top of #3 for many years and pee ate away all the fins. Also fused the head to the studs so that head is similarly ruined.
A friend of mine had these I was considering either using one of the good ones (which may still not be good) or having all of these refreshed and keep mine on a shelf.
Will post more pics tomorrow of P/Cs and heads. Those are scary.
Old 05-30-2015, 07:02 PM
Shaun
I should have some replacements
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 05-31-2015, 04:33 AM
Thanks Tom, hopefully I'll be going to NY this week and will stop by.
Here are the heads. I could take a million pics. I think the only way to determine if they are rebuildable is to bring them to Bob at Anchor Atlantic or similar. I cleaned these quickly with soda.
The real shame is that I think every head has something major wrong with it. The one pictured with a nice dome has an eaten away exhaust port and intake valve base is gone. But as 69S heads, I think they should at least sit on a shelf forever if necessary. The ones with bad domes and destroyed seats have good ports. All have an MFI injector hold plugged with a bolt, see top of last pic.
Old 05-31-2015, 05:16 PM
