-   -   New rocker-should I return it? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/875235-new-rocker-should-i-return.html)
Neilk 07-17-2015 05:09 PM
Hello,
One of my rockers backed out and looks a little worn, so I bought a new OEM one from our host. I was wondering if I should deburr the top part, but in taking the picture, I wonder if it is even worth installing. Thoughts?
http://forums.pelicanparts.com/uploa...1437178541.jpg
Flat6pac 07-17-2015 06:04 PM
Compare it to the new one, it looks anything but smooth and that's your valve lift.
Bruce
Neilk 07-17-2015 07:08 PM
That is the new one. The old one is a little marred on one side but looks much smoother.
So should I keep it?
al lkosmal 07-17-2015 10:14 PM
Return it...............crappy quality control.
regards,
al
safe 07-17-2015 11:42 PM
The top bit wouldn't worry me, but the surface looks horrrible for a new part. Return it.
Steve@Rennsport 07-18-2015 01:09 AM
Thats what a LOT Of new ones now look appear. Porsche's QC is not good anymore, which is why we look for use rocker arms and refurbish them.
Even new rockers MUST be reground so the pads are parallel with the cam lobes.
chris_seven 07-18-2015 02:08 AM
Originally Posted by Neilk (Post 8715333)
This casting clearly shows signs of porosity on its surface. It is possible that grinding may remove these defects but could also reveal more holes in the surface.
Not really very good at all.
Our forged rockers are shot peened after machining and then Isotropically Superfinished (REM) before being Nitrided using a modern PVD process.
http://i197.photobucket.com/albums/a...psgok160ua.jpg
Steve@Rennsport 07-18-2015 11:23 AM
Very nice, Chris!
Neilk 07-19-2015 01:07 PM
Thanks for confirming. I will return it and either get my old rocker resurfaced or find one that has already been reconditioned to proper spec.
