DSPTurtle's Avatar
Rocker Shaft Fun
Played with iMovie today while putting together a 1970 2.2L mag motor that has been punched out to 2.7L with GE40 cams. Should be an interesting little power plant when back together.
Rocker shaft installation can be exciting! Haha...
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 06-13-2015, 06:10 PM
Straight shooter
Lapkritis's Avatar
I'd like to get my hands on some of those rocker locks... just for piece of mind.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 06-16-2015, 07:37 AM
KTL KTL is offline
Schleprock
KTL's Avatar
TurboKraft Inc : Rocker Shaft Lock Set [901 105 360 TK] - $359.00
Kevin L
'86 Carrera "Larry"
Old 06-16-2015, 11:00 AM
TurboKraft's Avatar
Hi JB -- nice video, thanks for the props! Glad you like them. :-)
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 06-16-2015, 05:09 PM
Kartoffelkopf
Spenny_b's Avatar
Great video Jason, really nicely illustrated.
But....
...those overalls are FAR too clean - was that a body double actually spannering?
Chris did offer these to me for my build, and at the time I hadn't realised how completely over budget my project was going to end up, so I rain-checked [hindsight glasses=on] ....if I'd have known then what I know now, I'd have bought them without a moments thought. My rocker shaft bores are looking very nice, but for sure it's something I'll retro-fit next time I remove the cam covers for a look-see.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 06-17-2015, 12:15 AM
jkh2cpu's Avatar
Just ordered mine. Glad I stumbled across this :-)
John
Original Owner 1973 911T. Webers, SSI, SAW & Polybronze, Carrera chain tensioners, 'A' calipers
Old 06-17-2015, 03:46 AM
jkh2cpu's Avatar
Just putzing around this morning checking the valve to piston
clearance, and I try out my TurboKraft rocker shaft locks. They
seem to be really loose when snugged up hand tight, but once
I torqued to specs, they are fine.
Is this how these work?
Any recommendations for thread lockers, or will the torque hold
them in place?
John
Old 07-23-2015, 09:11 AM
TurboKraft's Avatar
A dab of blue Loctite thread locker is more than sufficient.
The loose feeling is exaggerated by these having tabs on each end, farther from the shaft's center point.
Just make sure those tabs are not atop a casting seam.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 07-23-2015, 09:19 AM
