Question GT3 4.0 crankshaft fitment
Good afternoon,
A search found this thread about fitting an 80.4MM crank to a 930 case.
GT3 RS 4.0 crankshaft fitment
Can any of the engine builders and enthusiasts share their experiences with a normally aspirated build utilizing this crank.
Thanks!
Last edited by stephen1070; 10-05-2015 at 07:02 AM.. Reason: typo on stoke length - sorry!
Old 10-02-2015, 01:52 PM
The main point to remember is, the GT3 and the turbos of the present day use the 964 casting case for the powerful applications.
Bruce
Old 10-02-2015, 05:24 PM
Evan Fullerton's Avatar
Strictly to be pedantic, the Turbo stopped using the Mezger engine in 2009 and all 991 cars except Cup and RSRs use a 9A1 derivative engine.
Old 10-02-2015, 09:21 PM
Stroker
The 4,0 crank is 80,4 mm if you have a 84 mm crank it is probably one of my stroker cranks.
If you need background about this let me know - I'm happy to help.
Dirk
https://de-de.facebook.com/edelweissmotorsport
Old 10-03-2015, 03:24 AM
Thumbs up
Thank you for the replies - so it appears that the 964 casting is required to fit this crank. Any thoughts on the ideal rods and pistons for this configuration.
Old 10-05-2015, 07:12 AM
