3.0 RSR pistons. Will they work?
I am finalising plans for my 3.0 SC upgrade. It has 40mm PMO's. John recommends the the GT2-102 cam with the carbs and i can get some 3.0 RSR Mahle pistons. The pistons are 10.5:1. The engine is a 79 Euro SC, so has larger ports than the US spec.
Page 145 of the performance handbook states that the combustion chamber these pistons create is smaller than the SC and they should be avoided. Does anyone have any experience of installling them in a Euro spec 3.0 SC engine?
Alternatively i can go with the JE pistons.
Old 08-18-2015, 12:22 PM
0396's Avatar
I've been told that the spacing of the cylinder is larger than the S/C.
Old 08-18-2015, 01:14 PM
carrerarsr65
just got done with a 79 row engine big port twin plug,hpv-1 ign, j&e 10.5.to1 on these je pistons take the sharp edge off the top ,something to do with combustion,steve at rennsport sold me mine,any way 964 cams wich I think suck,bad choice on my behalf.weber 40idas header and a couple exhaust choices ,the megaphone are straight out bad ass sounding, I like the je though no smoke on start up
Old 08-18-2015, 07:09 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The Mahle 3.0 RSR piston has a theoretical compression ratio of 10.4:1 when used with the RSR head.
When you combine it with an SC head with a larger combustion chamber the result is a much lower compression ratio. If memory serve me, that number is under 9:1. If you can live with the resulting compression ratio they will work just fine.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-19-2015, 05:14 AM
camgrinder's Avatar
Way too low.
John Dougherty
Dougherty Racing Cams
Old 08-19-2015, 10:08 AM
After some quick calculations I came up with 8.6:1
31.2 cc dome
77.2 chamber =10.4:1
31.2 cc dome
90cc chamber= 8.6:1
Henry Schmidt
Ph: 760-728-3062
Old 08-19-2015, 10:59 AM
Skunk works
JV911SYDNEY's Avatar
Originally Posted by carrerarsr65 View Post
964 cams which I think suck,bad choice on my behalf
too mild?
964 RS-4
Old 08-20-2015, 04:44 PM
Too mild. Maybe the JE pistons will be a better choice. Many thanks for the feedback.
Old 08-21-2015, 01:07 PM
