Thanks for confirming my suspicion & thanks for your insight on the CP pistons.
Hello
It's often difficult to machine the plastic stacks, Did you bore them ? Philippe |
I bore both plastic and mag stacks inhouse. These were bored 46mm top and 41mm bottom. They are matched to a set of throttle bodies that were bored to take 41mm throttle plates. |
Nice work !
Thanks!
Hi Aaron,
I just have to say i love your work on this engine and i want to do the samething on my 3.0! But i like to know howmuch hp and torque this set up will generate? Cheers,ferry |
Hi Ferry, Horsepower is around 280 hp depending on the exhaust you choose. With a little more cam and a little less exhaust you can see 300hp.
Hi Aaron,
Beautiful build. Congratulations. I was wondering which method and media you have used for cleaning the case and all the other alloy to this brand new level ? Cheers, Kerem |
Thanks Karem,
I sub contract to a company that specializes in surface preparation. They are usually involved in the manufacturing industry and prep castings and machined parts. The service is not cheap, but the result is a very consistent and appealing finish. |
Nice build details Aaron.....good blend of mechanical know-how and aesthetic sensibility.
regard, al |
Thanks Al, the engine turned out very strong and is a great fit for the car.
http://forums.pelicanparts.com/uploa...1452529777.jpg http://forums.pelicanparts.com/uploa...1452529903.jpg |
Ooh, Mark's got a new motor? Sweet!
oh yessss....that looks like fun!
regards, al |
| All times are GMT -8. The time now is 10:39 PM. |
