CR of 2,4S pistons with a 2,2 crank
A friend of mine is rebuilding his 2,2T and I am helping him with buying the parts needed. The original 2,2T pistons arenīt availble anymore. But the 2,2E are. -but not before next year which is an issue for him.Cylinders are no problem.
Does anybody know where 2,4S pistons will end in Compression with the 2,2 crank and the T heads?
Many thanks, Malte
Old 09-15-2015, 03:34 AM
8.5 then 4 mm short on crank compressing..not much compression left
Bruce
Old 09-15-2015, 04:13 AM
911 2.2 T targa
I would keep te original iron cylinders and have them honed to an overzise and buy custom pistons from JE or Woesner to match them.
Old 09-15-2015, 05:13 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Many thanks, Malte
84mm bore
70.4 stroke
69 cc chamber
22.3 cc piston dome
Equals 8.5:1 static compression ratio, stock 2.4 S
Change the stroke to 66mm and the CR drops to 8.03:1.
That ration is low but doable for a touring type 2.2 engine. The engine would feel pretty anemic.
Ken @ 911 Vintage Parts (760-731-4911) may have a reasonably priced, set of 911 2.2 E pistons to fit your requirements.
info@911vintageparts.com
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-15-2015, 09:51 AM
Thank you very much! Do you think that 2,2s pistons will work? I am a little worried about the dynamic compression with the T cams. But on the other hand the worst fuel we have is 95 octane...
Old 09-15-2015, 01:02 PM
If you use an extra base gasket .25mm your compression will be reduced to around 9.5:1 leaving you safer on the detonation front.
Henry Schmidt
Ph: 760-728-3062
Old 09-15-2015, 01:35 PM
Perfect, -thank you very much (again)!
Old 09-15-2015, 11:08 PM
911 2.2 T targa
I also have S pistons with T cams. It runs great also on 95 octane, but had to adjust the timing curve because the standard 35 degree advance is a bit to much. I now have a 30 degree advance as this was original spec for S engine.
Old 09-16-2015, 12:52 AM
