Casesaver reinforcement of magnesium case
Im just about to send of a case to machineshop to do the 24 head stud treads with casesavers 10/14mm ,also im doing the 4 "3" studs to the transmission .
can anybody summerize what other treads needs reinforcement 10mm or 8 mm? Thanks |
Do 7 studs inside the case two on the very back lower corner near the oil pump the one at the top in the breather and the three long ones up in the front below the crank and the countershaft long one.
regards |
The long one by the intermediate shaft will pull out
Bruce |
The long one by the intermediate shaft will pull out and you need to split case to repair
Bruce |
abit off center
Yes as flat6 said twice do the 8mm at the IS for sure along with the cylinders
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Thanks all , apreciated
