PMO or Jenvey?
So I am getting parts together for my 1986 3.2 engine rebuild using euro barrels and pistons, upgraded cam etc and I am going to use electronic fuel injection using individual throttle bodies.
Any opinions on PMO versus Jenvey? price is about the same.
Old 12-14-2015, 11:33 AM
I have a set of Jenvey's on my '87 Carrera. If you look at the most recognized tuners, Rothsport, Singer, etc, etc, they all use Jenvey ITB's. To my knowledge, PMO are using the same offset spacing that Porsche used on their Webers and MFI systems, where there is a bend in the manifold on Cylinder 1, 3, 4 and 6, and only cylinders 2 and 4 have straight down manifolds. This might cause uneven filling of the cylinders. The Jenvey's are straight down on all six cylinders. If the price is the same, the Jenveys is a no-brainer!
Old 12-14-2015, 11:44 AM
Skunk works
JV911SYDNEY's Avatar
Jenvey all the way!
964 RS-4
Old 12-14-2015, 04:35 PM
Jenvey rules!!!
Old 12-16-2015, 11:03 AM
OK, so chatting to the race engine builder, he said I would make more low end power using a single throttle body and plenum setup. Any views? Does anyone make these with injection intakes?
The engine is going in a heavy VW van so low end power is more important, that in addition to limited height above the engine makes it an interesting challenge. Any opinions or pointers to who supplies these kind of intakes?
Old 01-03-2016, 11:30 PM
clutch-monkey's Avatar
so.. use the 3.2 intake?
Old 01-04-2016, 12:29 AM
My engine didn't come with the intake and I wondered if there was an updated option?
Old 01-04-2016, 10:43 AM
It's a 914 ...
stownsen914's Avatar
The Carrera 3.2 intake is considered a pretty good one as stock intakes go. I saw a used one here on the board recently for like $500, so not so expensive either compared to aftermarket options. If it's low end performance you want, that may be your best option.
Last edited by stownsen914; 01-05-2016 at 07:30 AM.. Reason: clarification in last sentence
Old 01-05-2016, 05:50 AM
order mine today from Jenvey.
PM me if your interested, great guy to deal with and might be able to help on price
Old 01-05-2016, 06:30 PM
Jeff Alton's Avatar
Jimtweet, did you order from Hayward?
www.turn3autosport.com
Old 01-05-2016, 07:53 PM
