-   -   Do I need to check deck height on each cylinder? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/891077-do-i-need-check-deck-height-each-cylinder.html)
tornik550 11-14-2015 07:25 AM
As the title says- do I need to check deck height on each cylinder? I have a magnesium case which was freshly machined by ollies, new connecting rods and used however reconditioned nikasil cylinders.
mreid 11-14-2015 07:27 AM
No, unless you are truly anal.
tornik550 11-14-2015 07:33 AM
Lol- definitely not me. Thank you
stownsen914 11-14-2015 03:08 PM
Shouldn't be a need to check every cylinder, as long as Ollie's decked the case (or checked it at least). There can be variations in the case
304065 11-16-2015 07:22 AM
Why not, other than spending an hour doing it? If you put it together and the cams bind because the cylinder heights are different you'll certainly check it after you tear it apart. At least measure the cylinder height, spigot height, depth of the recess in the head, etc.
SoyRacer 11-16-2015 07:08 PM
No. Just on the one that's different from the others . . . .
