Do I need to check deck height on each cylinder?
As the title says- do I need to check deck height on each cylinder? I have a magnesium case which was freshly machined by ollies, new connecting rods and used however reconditioned nikasil cylinders.
non-whiner
No, unless you are truly anal.
"Too much is just enough." |
Lol- definitely not me. Thank you
It's a 914 ...
Shouldn't be a need to check every cylinder, as long as Ollie's decked the case (or checked it at least). There can be variations in the case
Why not, other than spending an hour doing it? If you put it together and the cams bind because the cylinder heights are different you'll certainly check it after you tear it apart. At least measure the cylinder height, spigot height, depth of the recess in the head, etc.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
No. Just on the one that's different from the others . . . .
1973 Porsche 911 RS 1981 Porsche 931 Euro-Intercooled-GT 1984 Porsche 911 Euro Carrera widebody 1987 Porsche 924s Rallye Spec Instagram: @soyracer |
