-   -   915 trans question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/892177-915-trans-question.html)
hermanator 11-22-2015 03:34 PM
915 trans question
I have a 915 trans that the oil seal on the right side is weeping. this seal is behind the plate for the cv joint. the plate is held by a bolt in the center. can I just remove the bolt and pull the plate and seal? Is there some kind of crush factor when reinstalling
the bolt?.... TKS
lrodri64 11-22-2015 03:53 PM
HI,
With right side you mean passenger side?
If the oil is coming from the retainer, yes you can remove the hub and replace the seal.
Is my opinion.
I have done.
hermanator 11-22-2015 04:01 PM
yes.. passenger side.... and Thanks....... Gonna replace both with engine out...:)
