Chain fence eating turbo
What springs for 993SS cams in a boosted 3.2?
As the title says, what should I use?
I'll probably stay at 6750 RPM due to heavy flat top pistons that are 3.4, 98mm's on stock rods with ARP's.
This is a boosted engine that may see 2 bar occasionally, mostly 1 to 1.4 bar on the street.
Old 11-26-2015, 08:50 AM
abit off center
cgarr's Avatar
sounds like the same motor I have except I am na with a 7K limit running stock springs and I hit the limit a lot:
But with that cam, which I am not running might require at least street springs? Check with John about that:
______________________
Craig
G2Performance
Old 11-26-2015, 10:13 AM
Craig, you got away with the stock springs?
You rebuilt my heads; will the retainers clear the seals with these cams?
Old 11-26-2015, 10:59 AM
I work with some guys who have boosted Supra's
they went high lift aggressive cam and 2 bar without enough valve spring
they both blew the valves off the seat and had valve piston contact ....bent valves , keepers in oil ..ect
lots of fun before that happened ...
I would ask around ...at that boost level you are going where few have with some measure of reliability
Old 11-27-2015, 03:18 PM
