Does someone have a diagram of a 3.6 crank?
I want to make sure I have the rod journals and main journals labeled correctly. Thanks
Bonus question--how did you label the rod bolts when you measured them prior to installation (to check for stretch) for future reference in case you ever needed to reuse them (ARP)?
1980 911SC Targa 3.6L |
The spec is the same as a 3.2 except for forward of #8
Bruce |
Thanks Bruce but I'm not familiar with a 3.2 crank either. Im just looking for something really simple ei. an arrow "this is the no.1 rod bearing" or "this is the no. 4 main bearing".
#1 main is a heavy oil feed bearing to the rods as is #8. #1 starts at the flywheel through #8 is the solid Nose bearing.
Starting at 8 the first throw for the rod is #4, then #1, #5, #2, #6, #3. Bruce |
Under the radar
I used a mic to measure each bolt before and after torquing. I recorded the actual measurement of each with the rod number.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 12-12-2015 at 07:21 PM.. |
abides.
The machinist that resized my rods scribed a number on the head of each bolt.
Graham 1984 Carrera Targa |
