QSC Quality Specialty Components
Hi,
Has anyone used QSC's cylinders and pistons? Are they high quality? Thanks Scott |
I asked a similar question recently. Seems the consensus these days are to stay away. I think I read an old post somewhere about issues With the plating.
QSC Cylinders
Matt. 83 911SC 85.5 944 NA - Sold |
any info on the cast iron cylinders?
It's a 914 ...
If you do a search, you'll find some good and some bad reviews. At least one respected engine builder here on the forum sells them, but does inspect them individually and discards bad ones. I believe he sells inspected sets too.
With new Mahles sitting at +$4k, the less expensive stuff is enticing budget wise. If you are talking about using them in a turbo, my guess is that you won't get anyone here saying, "Go ahead, you'll be fine!" Cast iron? They simply don't shed heat like the aluminum cousins. Unless it's a low HP engine, you'd probably be better staying away from them. Good luck!
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
E-85 sippin drunk
The cast iron cylinders are a lot thicker, and should resist becoming "egg" shaped down the road. Also, the ring choices are amazing for cast iron cyl's .... IMHO, there are only three choices when it comes to cylinders for our cars, 1. LN Engineering "Nickies" 2. JB Racing's cyl's 3. Maule
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
I was talking about cylinders that are 100% cast iron. Sleeved with aluminum fins cool a bit better, 100% aluminum better still. Each has their own pros and cons. Theres a pretty good discussion about all that here and here. I believe some of the lower HP, detuned models like my 72 2.4T originally came with 100% cast iron cylinders. From there Porsche moved to biral then to aluminum (nikasil and alusil.) I considered boring my cast cylinders but decided to go with nickies and JE pistons, just my personal preference here.
