Vacuum for brakes with Jenveys?
So I am putting an 87 3.2 in my vw van. The engine will have a brake booster but I need a vacuum from the engine. Where can I take one from when using ITB's from Jenvey?
Old 01-24-2016, 03:59 PM
abit off center
cgarr's Avatar
Might not get the vacuum you need? If not they make a nice electric vacuum pump that can be used for brake booster, we have one on ours.
______________________
Craig
G2Performance
Old 01-24-2016, 05:01 PM
Craig,
I am interested to know why you can't get the vacuum. Is this because there aren't any bosses on the manifolds or is it more fundamental?
Old 01-25-2016, 02:12 AM
abit off center
cgarr's Avatar
With our webber setup using the Carrera brake booster in our track car we could never get the proper vacuum to operate the booster, most times running open throttle it never worked for us, the port on the 3.2 manifold is pretty large too, maybe for a reason. Not sure what type of booster they use on a VW Van? maybe that would work for this application?
Craig
G2Performance
Old 01-25-2016, 08:22 AM
VFR750's Avatar
Which one?
Old 01-25-2016, 09:03 AM
I have a '87 Carrera with Jenvey ITB's, and my vacuum brake booster works perfect! On each intake runner (below the butterfly) there is a vacuum port, and each of the 6 vacuum lines are connected to a vacuum manifold, that in turn is connected to a non return valve on the vacuum line to the brake booster.
Old 01-25-2016, 09:09 AM
Fly, got any pics?
Old 01-25-2016, 09:17 AM
ROW '78 911 Targa
timmy2's Avatar
Here is the one Rothsport uses for their Jevney installations.
Welcome to Rothsport Racing - Engine Products
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-25-2016, 10:02 AM
that's awesome!
Old 01-25-2016, 10:50 AM
beancounter
jwasbury's Avatar
VW van with ITB 911 flat six = awesome
I have Jenveys on my 3.0l 911 race car. The rothsport set up per the link previously posted. No issues with vacuum for the brake booster
Old 01-25-2016, 03:15 PM
I'd say the cam choice (usually a reason to use ITB) and average engine speed would determine the available vacuum.
Old 01-25-2016, 03:57 PM
Jeff Alton's Avatar
Not a problem to get enough vacuum even with big cams if you have a proper vacuum manifold.
Cheers
www.turn3autosport.com
Old 01-25-2016, 06:12 PM
Skunk works
JV911SYDNEY's Avatar
pics please!
964 RS-4
Old 01-26-2016, 02:51 PM
Jenvey vacuum port
Here is a link and some pictures. Paul
Hole size for vacuum port on an intake manifold
Thanks, Paul
1979 SC
"A man of many projects and too many hobbies"
Old 01-27-2016, 09:46 AM
