RTV Crankcase Bolts - Terrible or not?
All,
I got some feedback that RTV on those orings is not good because you can actually have bad oil leaks because of it and potentially getting foreign material in the crank mains. If this is so bad, how did it make it in Wayne's book? Is it really that bad or not. I was told I should take off my top end to remove the RTV and reinstall orings slightly lubricated. Has anyone had failures recently after rebuilds caused by using RTV here?
Thanks,
Kelly
Old 01-30-2016, 07:34 PM
Alan L's Avatar
I used as per Waynes book on my SC about 7 yrs ago. Not a drop so far.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 01-30-2016, 10:48 PM
VFR750's Avatar
Is the engine built and running?
Old 01-31-2016, 05:00 AM
I've been building for 35 years and have taken apart destroyed engines that were assembled with RTV including an early S engine.
Bruce
Old 01-31-2016, 06:34 AM
Bruce
Was the root cause of the destruction errant bits of RTV plugging up oil galleries and such?
As much as I trust Wayne, I must admit I don't like the practice....
Dennis
Old 01-31-2016, 07:10 AM
Alan L's Avatar
If you are referring to my SC - yes - has been for 7 yrs. Runs like a swiss watch. Off on a 1000 mile trip tomorrow. Has never let me down in 10 yrs .
Regards
Alan
Old 01-31-2016, 10:12 AM
JMHO,....
Without any exceptions, RTV should never be anywhere near a 911 engine during assembly.
I've seen FAR too many ruined engines over the past 40+ years from the use of that stuff. Leave it for the domestic engines.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-31-2016, 01:24 PM
Originally Posted by Steve@Rennsport View Post
JMHO,....
Couldn't agree more with this, from a materials science perspective. While some RTV silicones can withstand the temperature rigors of an engine application, those tend to be pretty expensive (they use a platinum cure system). But, more importantly, RTV is not compatible, as a rule, with hydrocarbon based fluids (oils, gasoline, etc.) unless it has been modified with fluorine (flourosilicone). I really don't know of any room temperature cure system that includes this modification. I sure wouldn't want to risk it. But I'm a polymer junkie, so maybe I over-think this stuff. Good luck.
Lyle.
Old 01-31-2016, 05:35 PM
I really didn't want to do to take it back down but I guess it's a good time before I install cams and time the engine.
Old 01-31-2016, 08:33 PM
Slippery Slope Expert
Steam Driver's Avatar
Baaad idea! RTV should never be used on an "O" ring, be it Porsche or your plumbing system. By design "O" rings need to be able to move, not be immobilized, which is what the RTV would do. The theory is that as pressure is applied to the ring, it deforms and seals even tighter. RTV will prevent that. Bottom line is no RTV on any "O" ring, regardless of application be it Porsche or your commode! Lubricants like Dow-Corning 111 or similar only.
Old 02-01-2016, 04:54 AM
Tom '74 911's Avatar
JMHO,....
I realize this is a bit more than thru-bolt o-rings, but to Steve's point, here are photos of my (previously rebuilt by an "expert") engine after disassembly. One photo I didn't take was the literal handful of RTV bits I removed first thing when I split the case... Steve (or more likely his elves) had the pleasure of scraping all that cr@p off the mating surfaces & everywhere else it spread when I had Steve/Rothsport rebuild the recently rebuilt engine for me. : ) : )
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 02-01-2016, 02:26 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Wow Tom's pictures are bad............ If you ever get a chance to see how small the holes are in the cam housing spray bar, you'll agree that RTV is bad news for these engines. OK, I can't resist. They're basically pinholes
Unfortunately the thru-bolt o-rings act like more of a packer than an actual o-ring. Regardless, the goal is to get them installed without being excessively mangled, which would cause a leak. I believe the recommendation of RTV in the rebuild book was to counteract the mangled o-ring occurrence.
There was a "friendly" debate about this and if you can wade thru some of the argument, there was some pretty good discussion
Your opinion wanted. Green bolt through viton o-rings with rtv
Case Through O-Ring trouble??
Kevin L
'86 Carrera "Larry"
Old 02-01-2016, 02:53 PM
