Vacuum for brakes with Jenveys?
So I am putting an 87 3.2 in my vw van. The engine will have a brake booster but I need a vacuum from the engine. Where can I take one from when using ITB's from Jenvey?
abit off center
Might not get the vacuum you need? If not they make a nice electric vacuum pump that can be used for brake booster, we have one on ours.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
I am interested to know why you can't get the vacuum. Is this because there aren't any bosses on the manifolds or is it more fundamental? |
abit off center
With our webber setup using the Carrera brake booster in our track car we could never get the proper vacuum to operate the booster, most times running open throttle it never worked for us, the port on the 3.2 manifold is pretty large too, maybe for a reason. Not sure what type of booster they use on a VW Van? maybe that would work for this application?
I have a '87 Carrera with Jenvey ITB's, and my vacuum brake booster works perfect! On each intake runner (below the butterfly) there is a vacuum port, and each of the 6 vacuum lines are connected to a vacuum manifold, that in turn is connected to a non return valve on the vacuum line to the brake booster.
Fly, got any pics?
ROW '78 911 Targa
Here is the one Rothsport uses for their Jevney installations.
Welcome to Rothsport Racing - Engine Products
that's awesome!
beancounter
VW van with ITB 911 flat six = awesome
I have Jenveys on my 3.0l 911 race car. The rothsport set up per the link previously posted. No issues with vacuum for the brake booster |
I'd say the cam choice (usually a reason to use ITB) and average engine speed would determine the available vacuum.
Not a problem to get enough vacuum even with big cams if you have a proper vacuum manifold.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Skunk works
pics please!
964 RS-4 |
Jenvey vacuum port
Thanks, Paul 1979 SC "A man of many projects and too many hobbies" |
