VFR750's Avatar
Taper in new exhaust valve
How much taper is acceptable in a new exhaust valve?
Top of stem: 0.3527"
Bottom of stem: 0.3518"
Note, my micrometer doesn't have a vernier scale, but I snapped pictures of the measurements and estimated the 4th significant digit with some accuracy.
This exceeds the factory specs.
Old 01-19-2016, 03:20 AM
VFR750's Avatar
Brand new, out of the box.
Old 01-19-2016, 03:39 AM
VFR750's Avatar
Somewhat self-explanatory.
OK 0.3526"
Factory spec is .3519-.3523.
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 01-19-2016, 04:14 AM
abit off center
cgarr's Avatar
What brand of valve? Intervalve by chance?
______________________
Craig
G2Performance
Old 01-19-2016, 12:56 PM
VFR750's Avatar
No, TRW. Nice smooth ground surface.
But it felt looser in the guide than the intervalve. That is when I checked. Multiple times. Intervalve had virtually no taper. TRW valve did.
Pelican has authorized the return. And I'm going with an intervalve replacement.
Old 01-19-2016, 03:44 PM
VFR750's Avatar
Good news. Sent the TRW valve back to pelican for a full refund.
Glenn said he had better luck with intervalve. So I ordered one of them.
Wow. 0.3526" top to bottom. Perfect. Not a hint of taper!
And the stem was nice and smoothly ground. A very nice exhaust valve.
Which is a little ironic, because lately intervalve has gotten a bad rep. That's why I chose TRW. Well maybe the Swiss made intervalve is the better valve after all. At least the one I just bought.
Old 01-29-2016, 04:22 AM
E Sully's Avatar
I used the Intervalve 5 years ago on my 3.2 rebuild with no issues.
Ed
1973.5 T
Old 01-29-2016, 07:02 AM
Daugaard's Avatar
Valve
This is all wrong.
The exhaust valve need to have taper, because the head end of the valve get more hot and expand more.
If you have a valve with no taper it's not porsche or OEM like TRW.
From porsche data book:
Exhaust valve (conical) 8,94 - 8,96 x 109 mm
Intake valve (sodium) 8,97 x 110,1 mm
The inlet valve is both thicker and longer.
Daugaard
Daugaard
Old 01-29-2016, 02:56 PM
VFR750's Avatar
Except the running clearance new is 2-3x the thermal expansion. And a worn in guide ( within limits) is 5-6x more clearance than the thermal expansion of the valve stem. So it is not possible to seize the stem in the guide.
The data I have doesn't say anything about a desired taper. Just cylindrical dimension.
Old 01-29-2016, 03:38 PM
Daugaard's Avatar
valve
Hi.
The data is from this 964 / 993 engine repair manual:
http://www.pcarworkshop.com/images/a/ae/AfterSales_Training_-_Air_Cooled_Engine_Repair_-_geolab.pdf
Page 16.
But the taper for the exhaust valve is the same 3,0 and up.
Daugaard
Daugaard
Old 01-30-2016, 03:22 PM
0396's Avatar
Daugaard
Thanks for the link, great info.
Old 02-01-2016, 07:45 AM
