Alan L's Avatar
cam chain tension
I've read the threads and this has come up before. But I don't see why the regular spring loaded tensioners are not appropriate for setting a consistent tension for cam timing. We seem to go to a lot of bother to come up with a range of mechanical tensioners - to accomplish what function that the engine tensioner can't perform? And wouldn't the engine tensioner be closer to the actual tension the cams operate on?
I ask this after just having spent half a day making a RH tensioner.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-09-2016, 09:04 PM
