-   -   Rocker on 4 and 5 redish and rusty looking (http://forums.pelicanparts.com/911-engine-rebuilding-forum/902309-rocker-4-5-redish-rusty-looking.html)
75 911s 02-13-2016 05:43 AM
1,2,3 and 6 are normal looking. Rocker 4 and 5 have a rusty appearance.
4 also had one very black and oil covered spark plug.
What do you think?
http://forums.pelicanparts.com/uploa...1455370816.jpg
A little background. A 75 911S 2.7 Car has been sitting for 10 years with bad fuel pump and accumulator. Got it running oil pressure reads fine.
Amstaff 02-13-2016 07:17 AM
Looks like water got inside the valve cover
75 911s 02-13-2016 07:28 AM
Right, my first thought too. So not oil starvation and overheating right? That would look different?
The valve covers had a thick silicone bead with old gasket. I cleaned up both surfaces and put just the new gasket in and tighten the new hardware down in a star pattern snug.
mreid 02-13-2016 08:06 AM
That's the intake side. What does the exhaust side look like on those cylinders?
SoyRacer 02-13-2016 11:58 AM
also look to see what the lobe surfaces on the cams look like. If they're pitted you may me inadvertently milling metal particles off of the cams/rockers and into the engine. Don't fire this engine up any more if you can ovoid it.
KTL 02-17-2016 08:29 AM
#4 has a leaky valve guide
75 911s 02-19-2016 01:43 PM
Here is the Exhaust side
http://forums.pelicanparts.com/uploa...1455918082.jpg
http://forums.pelicanparts.com/uploa...1455918205.jpg
75 911s 02-19-2016 01:52 PM
Best I can get of the lobes I cant see immediate pitting. I'll check when I do the valve job.
http://forums.pelicanparts.com/uploa...1455918684.jpg
http://forums.pelicanparts.com/uploa...1455918705.jpg
http://forums.pelicanparts.com/uploa...1455918724.jpg
