Registered Minimalist
75 911s's Avatar
Rocker on 4 and 5 redish and rusty looking
1,2,3 and 6 are normal looking. Rocker 4 and 5 have a rusty appearance.
4 also had one very black and oil covered spark plug.
What do you think?
A little background. A 75 911S 2.7 Car has been sitting for 10 years with bad fuel pump and accumulator. Got it running oil pressure reads fine.
Old 02-13-2016, 05:43 AM
Looks like water got inside the valve cover
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 02-13-2016, 07:17 AM
75 911s's Avatar
Right, my first thought too. So not oil starvation and overheating right? That would look different?
The valve covers had a thick silicone bead with old gasket. I cleaned up both surfaces and put just the new gasket in and tighten the new hardware down in a star pattern snug.
Old 02-13-2016, 07:28 AM
non-whiner
mreid's Avatar
That's the intake side. What does the exhaust side look like on those cylinders?
"Too much is just enough."
Old 02-13-2016, 08:06 AM
SoyRacer's Avatar
also look to see what the lobe surfaces on the cams look like. If they're pitted you may me inadvertently milling metal particles off of the cams/rockers and into the engine. Don't fire this engine up any more if you can ovoid it.
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 02-13-2016, 11:58 AM
KTL KTL is online now
Schleprock
KTL's Avatar
#4 has a leaky valve guide
Kevin L
'86 Carrera "Larry"
Old 02-17-2016, 08:29 AM
75 911s's Avatar
Here is the Exhaust side
Old 02-19-2016, 01:43 PM
75 911s's Avatar
Best I can get of the lobes I cant see immediate pitting. I'll check when I do the valve job.
Old 02-19-2016, 01:52 PM
