wprater's Avatar
HELP and advice! Major mess-up! Mated my case halves today; was not all as planned
Three things happened:
1. Over-troqued the through-bolts: set my digital torque wrench to 35 ft-lbs. vs 35 Nm (so about 10 ft-lbs. over).
I have not reverted this yet, do I need to do so immediately?
2. While torquing the perimeter bolts on the case halves, I noticed one bolt was missing! So now the case is probably not sealed.
If I could get this bolt in now, would it even be worth trying to torque it, since the case is sealed without it torqued in that area?
3. I realized the 15mm nut for the timing chain area I had was the wrong thread pitch. Hardware store gave me the wrong one and I must have check on the wrong area.
thoughts, input, and advice are very much appreciated!
that 45 minute window really stressed me out.
1971 911T (Tangerine)
1973 911T (Light Yellow)
1978 911SC -- "Northy" 3.2 twin plug
1990 911 Carrera 2
Old 02-13-2016, 04:05 PM
Ok, this is tough to swallow but start over. You haven't lost anything but some sealant at this point but if you put the whole thing together and you have a leak it is an expensive venture to reseal it.
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 02-13-2016, 04:46 PM
VFR750's Avatar
If you don't like the results. Do it over. Sounds like you are not happy with this build. That feeling won't easily go away. Better to do over then wonder why you didn't.
Old 02-13-2016, 04:54 PM
wprater's Avatar
yeah, already starting to take it apart.
you think case or through bolts could be damaged?
1990 911 Carrera 2
Old 02-13-2016, 05:01 PM
No, over torquing by 10 lbs shouldn't do any damage.
Tom Feeney
1970 911 T
1973 911 T
Old 02-13-2016, 05:29 PM
When you are ready for reassembly set out all of your nuts, washers and bolts in advance. Count everything so that you know nothing is missing. Have all of your sealants handy too.
It is also helpful to write down all of your torque settings so that you don't have to dig through the book to find them.
Tom Feeney
1970 911 T
1973 911 T
Old 02-13-2016, 05:33 PM
SoyRacer's Avatar
I actually disagree with disassembly but my opinion is also influenced by what the ambient temperature has been of the engine and how much assembly lube was used (and where).
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 02-13-2016, 05:39 PM
wprater's Avatar
it's not a fun process for sure. removing crank and cleaning all these webs.
I'm not sure if I used enough sealant, but the temp in my shop isn't very hot. maybe 60f.
the sealant is still wet and sticky after a couple hours.
I have some pics of the sealant left of the case after taking them apart.
the through bolt o-rings were also pushed through the holes a bit. maybe from over torquing?
1990 911 Carrera 2
Old 02-13-2016, 05:58 PM
If the loctite is still liquid when you pull it apart just recoat and retorque. Remember that the loctite dries only when the air is removed so anything out the outside will always remain liquid. Putting too much on is not an issue as it will not harden and will be drained after you run your break in oil.
Tom Feeney
1970 911 T
1973 911 T
Old 02-13-2016, 06:03 PM
wprater's Avatar
I used ThreeBond 1184 on the perimeter, so it's kinda sticky now.
also the loctitie dried up in bearing notches, so I got to clean those now too.
going to need to remove the oil pump and intermediate shaft and put this through the parts cleaner.
thanks for you advice!
1990 911 Carrera 2
Old 02-13-2016, 07:00 PM
Air Medal or two
afterburn 549's Avatar
Why do you have locktite in the bearing notches?
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 02-13-2016, 09:33 PM
wprater's Avatar
you can see what I mean in this pic
1990 911 Carrera 2
Old 02-13-2016, 09:52 PM
Air Medal or two
I am not familiar with that trick.
Unless that is a new proven method I would not do that.
However, you will sleep better doing the whole thing over ....
But check on the Loctite in the bearing notch.
AFAIK it will do nothing. The bearing gets seated as the two halves press it into its saddle.
The tabs are a mechanical lock to stop it from spinning.
The Loctite will take up some space.
Old 02-13-2016, 09:58 PM
wprater's Avatar
and here is what the viton orings looked like after I took the recently torqued bolts out; is this normal?
1990 911 Carrera 2
wprater's Avatar
But check on the Loctite in the bearing notch..
It was just a manifestation from the loctite applied on the bearing webs there, I guess it leaked in?
1990 911 Carrera 2
Old 02-13-2016, 10:00 PM
Air Medal or two
OH! OK , now I understand .
Old 02-13-2016, 10:08 PM
You did it right, locktite on the block webbing is correct.
Tom Feeney
1970 911 T
1973 911 T
Old 02-14-2016, 05:33 AM
Air Medal or two
You lost nothing but 8 hours ......Could be worse.
I still do not understand the stuff in the main bearing saddles..
Old 02-14-2016, 07:50 AM
VFR750's Avatar
Are the case holes chamfered?
One side of my case was chamfered the other side was not. I added chamfers and I have no leaks or extruded orings.
Old 02-14-2016, 09:25 AM
wprater's Avatar
Id never known to look for chamfers on the case, only the washers. but after reading this thread, it's clear some prefer them
going to check if it's one side, or none. I dont recall seeing them, but it seems the bolt end that should be on these case chamfers if they're one sided.
1990 911 Carrera 2
Old 02-14-2016, 02:38 PM
