wprater's Avatar
Breather cover for 1978 SC
I've got this beat her cover. however, when does one need the version with the sender unit threads?
also, what is that threaded hole next to it on the case? ideas?
1971 911T (Tangerine)
1973 911T (Light Yellow)
1978 911SC -- "Northy" 3.2 twin plug
1990 911 Carrera 2
Old 02-22-2016, 11:03 PM
The sender is used as part of the lambda system on 80 to 83.
The threaded hole is a 6mm bolt to hold down the shroud.
Bruce
Old 02-23-2016, 02:59 AM
wprater's Avatar
thanks, Bruce!
1990 911 Carrera 2
Old 02-23-2016, 09:49 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Also the breather with threads for a sender is used on the '84-'89 3.2 to activate the heater fan on top of the engine. Also the 930 engine has a thermo valve installed in the breather.
Get an earlier magnesium breather cover to save yourself 4 ounces? I don't know if that's the actual difference in weight. But I do know they're light as a feather (I have one on the shelf).
Kevin L
'86 Carrera "Larry"
Old 02-26-2016, 08:03 AM
