My friends call me Phish
2.7 E Weber setup
I have been running this carb setup for about 6 months, and the car ran great, or at least what I think. Until I did some research and found out that the engine might be running lean.
CURRENT CARB SETUP
Venturis: 32
Main Jets: 125
Idle Jets: 60
Emulsion: F26
Air Correction: 180
MY ENGINE
2.7
E Cam
9.5:1
SSI
M and K Exhuast
The setup that ************ recommended was to run this, but I think the Air Correction seems low. Thoughts?
Venturis: 34
Main Jets: .145
Idle Jets: 60
Emulsion: F3
Air Correction: .140
Old 02-12-2016, 05:02 PM
Put 160 A/C's in there and you'll be good.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-12-2016, 10:29 PM
Steve,
Do you think 140 is too small?
Old 02-12-2016, 11:12 PM
I installed this combo
Venturis: 34
Main Jets: .145
Idle Jets: 60
Emulsion: F3
and the car felt very sluggish, so I decided to put in the AC at 180 and it improved but it doesn't have that "POP" from the previous setup
Venturis: 32
Main Jets: 125
Idle Jets: 60
Emulsion: F26
Air Correction: 180
I think I am going to go back to this and see if I can get that "POP" back.
Does anyone think they might know why it might not have that pop?
Old 02-19-2016, 05:50 PM
32mm vs 34mm venturies.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 02-19-2016, 08:00 PM
I reinstalled this setup
Venturis: 32
Main Jets: 125
Idle Jets: 60
Emulsion: F26
Air Correction: 180
and the car runs a lot richer and it has better acceleration then the recommended setup. How is that possible?
Venturis: 34
Main Jets: .145
Idle Jets: 60
Emulsion: F3
Old 02-21-2016, 05:31 PM
The pop or back fire through the intakes usually means you're running lean.
Bruce
Old 02-22-2016, 04:56 AM
rennzeit's Avatar
I think he meant figurative pop, like responsiveness.
The smaller 32 venturi gives a stronger vacuum signal to the main jets, pulling more fuel earlier in the revs. So even though the main jet is smaller, it is providing more fuel.
1972 914-6 2.5L Gemini Blue
1973 914-6 MetalCraft Racing C-Prod/TransAm/IMSA history
Old 03-03-2016, 12:09 AM
