wprater's Avatar
Question Grease up rings for CC heads on engine?
After reading half a dozen threads on a good way to CC my heads through the plug hole, they all seem to mention greasing the rings to stop the seepage from the fluid used to CC (IPA).
Im a bit worried about greasing these rings. Can I use lubrathane poly lube to grease them? Afterwards just remove them from the cylinder and clean up and re-apply a thin oiling (as I did on initial install?)
TIA
1971 911T (Tangerine)
1973 911T (Light Yellow)
1978 911SC -- "Northy" 3.2 twin plug
1990 911 Carrera 2
Old 03-21-2016, 01:39 PM
Yep. I use red bearing grease. Cleaned them afterwards. No issues. Never gone the plug hole route. Just ccd the heads then the cylinders. Easier IMHO.
Old 03-21-2016, 05:25 PM
wprater's Avatar
Thanks for the clarification. I dont have a plexiglass disc to use for cc with the other methods, but I do have a nice fill tube I can use for the plug hole measurement.
1990 911 Carrera 2
Old 03-21-2016, 06:17 PM
If you need a disc easiest route is to order on from Mcmaster carr.
Old 03-21-2016, 06:31 PM
wprater's Avatar
nice tip! they already have a 4" disc. I don't have a saw that'll cut it down, so I'm going to try the other method. will report back in my build thread!
thanks
1990 911 Carrera 2
Old 03-21-2016, 07:49 PM
